Question about Electrical Supplies
Kohler m340 automatic transfer switch looses it's clock time whenever it transfers. Is there any way to get a hold of the manual or how to fix the power down error?
  • 2,760 Answers
Try this :
http://www.kohlerpower.com/onlinecatalog/pdf/g6076.pdf
this thing is all electronic if it looses it's settings it's gotta be defective
Posted on Jun 05, 2014
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Posted on Jan 26, 2009
  • 11 Answers
SOURCE: 6.5 RV Onan generaotr wont kick in when loaded.
The voltage regulator (AVR ) already faulty.
Posted on Mar 21, 2009
mamicheddy
  • 79 Answers
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Posted on May 10, 2009
  • 26 Answers
SOURCE: Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Posted on Jul 09, 2009
SOURCE: When utility power goes out, the transfer switch doesn't transfer
Call an electrician.
Posted on Jan 23, 2010
First start up
Try disconencting the remote start wires between the transfer switch and the generator, if ot still does it you have a bad control board. If it stops, then check the transfer switch for correct wiring of utility and generator power wires, also check with an ohm meter if the run contacts in the transfer switch are closed, that would indicate loss of sensing, or bad board
Jul 19, 2013 | Kohler Electrical Supplies
Kohler automatic transfer switch RDT CFNA 0100B. I can set it to exercise and it will do so for several weeks then it forgets. No fault shown.
Product manual does not have troubleshoot section.
The operation might be normal, and within expected parameters, or it might have a glitch.
Suggest you contact Kohler Power directly:
http://kohlerpower.com/contactus/contactus.htm?sectionNumber=
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 29, 2012 | Kohler 100-Amp Automatic Transfer Switch ...
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Just finished installing a 20 KW Generac generator (fueled with natural gas). The included transfer switch will not automatically transfer to the generator, but transfers back to the utility without...
Check the connections on the tranfer relay and two coils. The two coils have blue wires. I have seen them come off from assembly or shipping its common. Each coil has two blue wires #8 and E1 with crimp steak ons and limit switches make sure there all pushed on all the way. Hope this helps
Mar 09, 2011 | Generac Guardian RTSE200A3 200 Amp...
I have a Kohler 25kw that runs on LP that will not stay running. When you switch to manual start, it will run than shut back down like it is not getting fuel. The LP pressure at the regulator is correct.
If you are sure the regulator is ok and that the engine is getting the correct amount of fuel, then check for any throttle linkage issues, high speed fuel adjustment settings, loose carburetor mounting bolts, air/vacuum leaks, etc.
Also check to see if the engine has oil pressure cutoff, low coolant cutoff (if water cooled), and overspeed control.
Also, does it transfer and then shut down or will it even transfer? Make sure the transfer switch is ok and there aren't any issues with loads, etc.
Dec 31, 2009 | Kitchen Appliances - Others
Need circuit diagram for Kohler ATS part # K163341-800
Do you know the part number on the board. Kohler used numbers written with permanent marker on their controls boards. They usually started with a letter like A or B.
You might have a * 297373 or *297375. They usually had a big orange relay that stuck up in the middle.
The filter capacitors would always dry out over time and relays wouldn't energize correctly.
Depending on the board we might have a drawing.
We fix some of the older style. Check out our website: www. flightsystems.com. You'll find contact info. For fast response call in and be prepared with any board numbers you might have found!
Sep 02, 2009 | APC Automatic Transfer Switch (AP7701)...
My Kohler 17RES has stopped doing it's scheduled weekly exercise. How can I get it exercising again?
On your Automatic Transfer Switch ( the little gray box you see on the right in the picture above) you have two blue buttons. One is a Manual test switch. The other has a clock on it and this is your exercise set button. Hold it down for a FULL 3 seconds if you want it to excercise without a load (not powering your home) Hold it down for a FULL 6 seconds if you want it to exercise with a load every week. Your generator will start and run for 20 minutes, and then shut down. Now every week your generator will exercise at the time and day that you pushed the set button.
Aug 08, 2009 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
331 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
