Question about Magellan RoadMate 2000 GPS Receiver
My magellan 1700 won't turn on, even after I reset it and put in a new battery
My magellan 1700 won't come on, I put` a new battery in it, slid the button to reset and nothing, not even charging
    Sergeant:
  • 435 Answers
If you have a volt ohm meter see if theres voltage at the power adapter plug
Posted on Feb 13, 2015
SOURCE: won't charge
Are you sure the plug in secure. If not, re-solder the plug. Take it apart and becareful around the plugs on the side
Posted on Mar 11, 2009
  • 1111 Answers
SOURCE: my magellan GPS will not turn on or charge. I tried
these models and many other magellan model have issues with the power port failing..if you have a friend that has the same model, borrow his/hers and try the cradle on your gps and see if that works..im sure that power connection on that model is on the cradle.
Posted on Jun 15, 2009
  • 3 Answers
SOURCE: magellan 4250 blue screen, not able to reset
This may mean that the GPS was formatted and there is no data on it. So basically, you can't do anything with it because all the maps and software were deleted.
Posted on Jun 22, 2009
  • 1111 Answers
SOURCE: My magellan in not holding a charge to well do I
chance are its not the battery!
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it themselves.
you can get it repaired, or the part here
Posted on Aug 18, 2009
  • 1111 Answers
SOURCE: my magellen 3100 battery will not charge
its probably not charging...very common problem with this and many others.
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Posted on Oct 09, 2009
My Magellan roadmate 1700 doesn't open completely ,how can I fix it?
I had to send my 1700 back, contact magellan & see what they say
May 15, 2014 | Magellan RoadMate 800 GPS Receiver
How do you reset a Magellan 1700 GPS?
FAQ on your unit says this.
Depending on the power switch your unit was designed with follow the instructions below:
Slide Switch If your unit has a Slide power switch then slide and hold the power switch in the off position for more than 8 seconds.
Push Down Power Button If your unit has a Push Down Power Button for a Reset pin hole on the bottom or on either side of the unit. Take a pin or an end of a paperclip and insert it into the hole and push in until you feel it pop slightly, hold it for 10 seconds. Your unit will reset itself.
Reset Power Switch If your unit has a Reset Power Switch then it will have a three position power switch (Reset, Off, On), if this is the case slide the switch to the reset position and hold it for 10 seconds to perform the reset.
If that doesn't work, contact them direct. sometimes they have to install clean firmware.
MagellanGPS Technical Support Consumer Sales Customer Service
Apr 08, 2017 | Magellan Roadmate 1700
Magellan 1700 goes on and then quits working
If it has not been used in a long time or is a few years old it may not be charging the long life battery--bad fuse in the lighter plug etc.
Jun 16, 2012 | Magellan RoadMate GPS
My gps 1470 won t come on. I pluged it to my computer w/usb and turn it on and nothing. I plug it in to my car and it would not turn on or recharge.
Sounds like a problem with your battery. My 1700 will not start up when I connect it, if I have let my battery completely discharge. I have to leave it on charge for half an hour before it will restart. I also have had to reset it on occasion. I suggest you leave it on charge with a charger that connects to your house (120volt to 5volt adapter). If you have one for your cell phone or any other device that uses the mini USB connection, this will work on your gps.
Jan 19, 2011 | Magellan RoadMate 1470 GPS Receiver
Magellan 1700 tried to do an update and afterwards all I get is the loading screen. The unit will not completely start up.
I found the same problem occured to me.'After the first download you have to disconnect the cable let the unit reboot and run for a few mins then reconnect for a further download. Had to do this twice and now my 1700 and my 1470 both work great.
Hope this helps
Nov 11, 2010 | Magellan 1700 GPS Receiver
My magellan 3250 will not turn on .I charged it,do you have to put new batteries in it???
its probably not the battery, even though most self proclaimed experts on here will tell you that...dont buy anything until you verify whether its the battery or the power port...could even be a problem on the board.
plug it in to a know good charger for a few hours, then press and hold the power button for up to ten seconds...if it fails to start, its probably the power port...a new battery will probably get it started, but youll have the same problem once it dies.
Bill
EX
Standing Member of G.O.T.
Sep 27, 2010 | Magellan RoadMate 800 GPS Receiver
My magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
Dec 18, 2009 | Magellan RoadMate 1440 Car GPS Receiver
Gps wount turn on
You have to reset it look in the manual that shows
the reset slid switch and button on the left side of the unit under the rubber cover.
Dec 28, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan roadmate 2000 will not turn on!!! help please!!!!
You have to reset the unit with the slid switch and reset button on the teft side under the rubber cover
see your manual.
Dec 27, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
272 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
