Question about Health & Beauty
Audi Repair/96 Audi A4 wont startAdvertisementFollow-Ups to Answer from Expert GregAlbert wrote at 2007-12-17 23:19:20Greg,I am the original owner of a 98 A4 2.8 Quattro and I just started to have the same problem. Engine cranks but won't start. It starts in the a.m. fine but then if I drive for a short distance turn off the engine and then try to restart it, it MAY NOT. I have no idea when and why it decides not to start. If it won't start, it takes several attempts for it to get going. I am afraid to burn the starter or kill the battery. Haven't done that yet. When I drive to work and park in the garage, the car will always start 8 hrs later on my way back home. My mechanic who serviced it in August just can't figure it out. He ran the diagnostics test on it twice. The car drives beautifully ones it gets going, no problem whatsoever. 98K miles and the engine is superb. I believe it is an electronic problem that has to do with the onboard computer or some sort of relay module. I want to trade the car but I am afraid to go to the dealer and have it stall on me on the lot. I have done some research on the Audi Forums, identified several others with the same problem but not the solution. It stalled on me today, and I called the tow truck. By the time the guy arrived,the car decided to start. It is definitely, not the ignition, nor the fuel pump, or coolant sensor, or the fuel injector, or the V belt or alternator. I recently replaced all those for 5k. I took a stupid gamble because I love this car so much, nothing else in that category drives likes it.
    Master:
  • 992 Answers
These intermittent problems are always hard to figure out. If it is somewhat predictable, take the car to the garage once you have run it a bit and it won't restart.so they can run the diagnostics on it then.
Posted on Mar 03, 2017
SOURCE: Intermittent lack of full charge
It's the holiday season - take it back to where ever it was purchased and tell them you got it for Christmas and you would just like to exchange it for one that works. They have a 2 year warranty, if you want to go the hard way. You won't need a receipt, or a box. I spoke with Braun Customer Service and they advised me to just take, the one I had, back to the store where it was purchased, and get a new one. This is a great time of the year to exchange it. The Braun Customer Service number is 1-800-BRAUN-11. I'm glad, I just exchanged the one I had, because, my father says it's the best shave he has ever had.
Posted on Dec 29, 2007
csmock132
  • 4669 Answers
SOURCE: 96 grand cherokee cranks but wont start and stalls sometimes
Sounds like a crank sensor.
Posted on Feb 27, 2009
SOURCE: BMW 740i Stalling Issue (Fuel Pump/Line??)
the problem is your sensor is bad . the sensor for for the fuel pump is not sending power.
Posted on Mar 20, 2009
  • 1118 Answers
SOURCE: olds ciers 93 ... stalls, and mechanics can't solve help
I would look to see if you got a broken ground wire!!! witch are a big thing on todays computered cars. I know you have dumped a lot of money in your lawn ornament but one unhooked or dirty ground wire not making a connection can reak havick with everything, I would chk.for ground issues like around the fuel tank and where they hook to engine to body to frame or k-member.
Posted on Apr 14, 2009
  • 35 Answers
SOURCE: 200 Dodge Intrepid randomly stalls
Hey Brad!
So you're saying that there seems to be a relation between the headlights and the engine issue... Seems strange, but I've seen similar symptoms on a car where one of the clamps on the battery poles weren't secured tight enough (even though they did look/feel ok). Could also be that the ground wire (running from the negative pole on the battery) has a bad connection. Check and clean those first, it's both easy and cheap.
If it's not related to the battery you might have a faulty sensor somewhere. If so you should check your onboard diagnostic sensor for any codes.
Good luck mate!
Posted on Jul 02, 2009
My audi. A4 96 wouldn't start, the key light is blinking, my electrician have tried bypassing the immobilizer by removing the immobilizer box. But the car still didn't start. Also, the fuel return hose is...
I tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem
in my ford explorer. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
Feb 25, 2018 | 1998 Audi A4
Audi a4 b5 1996 1.8t aftermarket stereo wont work??
please test the fuse for open or dirty or corrosion or bad contact.
2) tight the wires connector very well.
3) see if the connection are propely connected and not missing
see the diagram attached.
God bless you
Jul 14, 2012 | 1996 Audi A4
1999 Audi A4 1.9 tdi aux drive belt diagram
The serpentine belt diagram for 1999 Audi A4 1.9 TDI:
CS = Crankshaft
F = Fan pulley
Gen = Alternator
T = Tensioner
AC = Air Conditioning
PAS = Power Assisted Steering
Please do rate my response. Thanks!
Jan 17, 2011 | 1999 Audi A4
I need an Audi owners manual, A4 2000 F/L
The following link is to a downloadable free manual for your car you may need to choose from a list of years, models, and options to get just what you need.
http://www.onlinefreeebooks.net/automotive-machinery-power-equipment-ebooks/audi/
Jul 09, 2009 | 2000 Audi A4
96 Audi A6 Front Bumper
No, they are not. THe A4 and the A6 chassis are different, the bumpers have a similar style and look to them, but they are not interchangable.
Jun 16, 2009 | 1996 Audi A6
1996 Audi A4 Automatic transmission wont shift when cold
Silly question: Have you checked the transmission fluid level, and is it to manufacturer's spec?
Mar 13, 2009 | 1997 Audi A4
How to input radio code for my s reg audi a4
Okay here are your radio options. Audi will charge about $125 to extract the code from the radio but you may try this first
1. Look in the owners manual. If the car has the original packet with the owners manual and other pamphlets, it is likely that the dealer wrote the code down and put it in there in the glove box.
2. Audi puts the 4 digit radio code on a sticker in the spare tire compartment in the truck. It is a four digit code that will begin with 1 or 0.
3. Audi will use the code 1111 as a default code on rebuilt or replaced radios. try that first.
4. still no luck.... go to the dealer and pay the $125 and have them extract it.
Dec 13, 2008 | 1998 Audi A4
96 audi a4 blowing cold air
yes, very possible. but first check your fluid level, thermostat.
Dec 06, 2008 | 1997 Audi A4
99.5 A4 Quattro Air con wont turn off
On some Audi's there is an ECON button which you must press for up to 5 seconds to turn the AC off.
Aug 07, 2008 | 1999 Audi A4
Health & Beauty Logo
192 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
