Question about Yookidoo Stack N Stream Tub Fountain
Bought the yookidoo stack n stream tub a year ago for when my granddaughter stayed, so usage has not been on a regular basis. On her last visit we found the batteries were dead, so naturally replaced them with new ones, checking the filter was clean. However it continues to not work. I really need some help here as she loves playing with it at bathtime.
My ford transmission is slipping. was rebuilt 5 years ago.
5 years is a long time and you don't mention how many kilometres you drove since the rebuild. These transmissions, like any other automatic, need the oil and filter changed on a regular basis to avoid untimely demise.
Jan 26, 2015 | Ford Cars & Trucks
The cd changer wheel if not turning anymore.
The belts last about 15 years, less depending on usage. Sounds like it's time for a belt replacement. Check out softduds on eBay, he can replace belts and adjust these players, he has lots of experience.
Aug 25, 2014 | Sony MegaStorage CDP-CX355 300-Disc CD...
GaSeveral years ago, we bought our granddaughter the zoo set and put it together for her. Then they moved and had to take it apart. Unfortunately they lost the directions. We are going out to visit them,...
The Playmobil company doesn't actually provide assembly instructions just a paper which includes all the pieces in the zoo.
Not sure which Zoo you have but here are two links to each one they sell. Hopefully the pictures will help a little bit.
Large Zoo
Children's Zoo
It's probably best to start by building your animal pens and the main zoo structure by snapping the pieces together. The pens and structure are built of the white brick pieces, the yellow railings and the green roof pieces. Assemble any animals that require assembly, such as the peacock. Simply match up the two pieces and snap them together. Decorate each exhibit with plants by snapping them into the plant holders.
Hope this helps!
Mar 05, 2011 | Playmobil Toys
Can i use regular batteries and not rechargeable batteries on my kodak cx4310?
Yes, 2 AA batteries. Just insert them correctly.
They don't last as long as the CRV3 lithium battery pack though
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I bought the CRV3 battery and charger at Radio Shack and love it.
Bought it 3 years ago, still using the same battery after taking 1,000's of pics. I also keep a pair of regular AA's as a back up when I'm away from home
Dec 22, 2009 | Kodak EasyShare CX4310 Digital Camera
Scratched cooktop
as far as i know its normal to have an scratched in glass ceramic hob defend how long to use or many times of use.do u think is same usage? its normal defend on usage.
Jun 20, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Computer won't stay booted.Replaced power supply a few months ago when I had this problem and it just started again
Sounds like the power supply is being suffocated with pet hair/smoke and it is overheating. A new power supply would have solved this issue until it eventually sucked in enough hair/smoke. If so, I would recommend canned air to clean out the insides on a regular basis.
Apr 13, 2009 | HP Pavilion a1630n PC Desktop
Stove igniter does not work and stove is only 2 years old how long does the warranty last on Maytag gas range
Most units bought in the last couple of years only had a one year warranty. Depending on usage the ignitor may go out every year.
Apr 24, 2008 | Kitchen Ranges
Lint Filter in Whirlpool Agitator washing Machine
I have a regular top loader and the lint filter is on the underside of the inner tub. You have to remove the inner tub to get to it. You might be able to find a service manual explaining this at appliancejunk.com.
Aug 22, 2007 | Whirlpool LTE6234D Top Load Stacked...
Kenmore Dishwasher (Sears Canada) 665-16532200
4 years old is not new! you took a risk by not taking out extended warranty and it didnt come off. sorry to be unsympathetic but a fault after 4 years is not unreasonable
Mar 27, 2007 | Kenmore 24 in. 16182 / 16189 Built-in...
Yookidoo Stack N Stream Tub Fountain Logo
499 people viewed this question
Top Yookidoo Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Yookidoo Retail Supply Expert? Answer questions, earn points and help others
