Question about Kicker 06ZX750.1 Car Audio Amplifier
Shortage outputtransister on a kicker amp
What does it look like? where is it? can i fix it?
    Guru:
  • 1,326 Answers
How do you know its a output transistor?? You can open the amp and normlly the transistors are black with 3 legs and are normally bolted to the metal frame of the amp body as they get very hot and need to dissipate heat
Posted on Sep 07, 2009
Kicker dx 250.1 class d monoblock amp has a fixed lpf at 80 hz 24db octave non adjustable. My car stereo is a pioneer deh-x55hd with the sub control set at 100 hz -6 slope unable to turn sub control off to...
Do you have the subwoofer amp connected to the pioneer thru pre amp connections; pre amp output of pioneer to pre amp input of Kicker amp. Page 10 of the manual explains how to adjust the subwoofer output. You can select the cutoff freq. that will pass to the subwoofer; The slopes don't match perfectly, but if you use the -12 slope , it should work fine.
Cut-off frequency:
50HZ
63HZ
80HZ same as kicker cut in freq
100HZ
125HZ
160HZ
200HZ
Output level:
24
to
+6
Slope level:
6
12
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X5500HD_OwnersManual112712.pdf
May 19, 2014 | Car Audio & Video
I have a kicker cvx 12" dual 2 ohm sub. It is seized. I was running it on a jl e1400d amp at 400 watts 1ohm. Is there a way to fix this problem?
Unfortunately no. Once the voice coil is blown, that's it. I know that kicker has some recone kits, but the speaker is not able to be broken down for repair. I think you can send them off to kicker for repair, but for the cost, you can almost buy a new one. Sorry, I know it's not what you wanted to hear. www.kicker.com
Aug 26, 2011 | Kicker Car Audio & Video
Amplifier over hit and shot off
set up is the most common issue. running amps at 2 ohm or lower specialy when bridged.bad speaker speakers can be bad and still play. sagging b + from battery.overdrivin inputs.ther are so many things that could cause this it is usally the install not the amp or at least intill the amp smokes from this condition.if your amp shuts off due to over heating the way it is instaled must be fix or ill see you at my repair center with your burned up amp.by the way kicker is one of a few verry few companies that dont make junk so if your kicker amp is shutting off its most likely not the amps fault
Mar 18, 2010 | Car Audio & Video
How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Nov 23, 2009 | Kicker KX600.1 Car Audio Amplifier
I've been running a kicker kx 800.2 and it has worked until now
Hello highryguy420,
It sounds like one or more of the output components is failing on the amp. You can contact Kicker support directly for instructions to return the amp for repair: support@kicker.com . Alternatively, if you have a local car audio shop that does component level repairs, they could perhaps save you some money and time.
Hope this helps.
Jul 14, 2009 | Kicker KX800.2 Car Audio Amplifier
Need to find out where to send kicker amp to have it fixed
depending on were you live you might be able to take it to your local car audio store if not you can send it in to Kicker to have it fixed for a fee..
Jan 28, 2009 | Kicker KX800.2 Car Audio Amplifier
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Kicker 06ZX750.1 Car Audio Amp... Problem
Kicker amps are good amps, I would weigh the cost of a new one against getting this one repaired and go from there.
Dec 06, 2007 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Kicker 06ZX750.1 Car Audio Amplifier Logo
114 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
