Question about Indesit Washing Machines
Wixl 125 The ON_OFF/DOOR LOCK Led flashes rapidly at the same time as at least one other LED I have an INDESIT washing machine model wixl 125 has this fault , when I connected it to electrical and close the door it still silent and no light nor action then after five minutes it is becoming flashing "on-off door lock + delay timer + stain removal"
MakikiChris
  • 84 Answers
SOURCE: Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Posted on Aug 12, 2007
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
SOURCE: indesit washing machine, wil103
Sorry, meant to add, if you switch the machine off at the mains once you've cleaned out the filter (bottom right corener, front of the machine, behind a plate), leave it for 2 or 3 hours and plug in again, sometimes it works.
Mine worked again the first three times, but I think this time it's had it and it's engineer and pcb time.
Posted on May 13, 2008
  • 3 Answers
SOURCE: Hi, we have an Indesit WIXL 143(UK)washing
This probably happens after the main wash has completed and it is just finishing the first rinse. It seems to be a warning that there is a partial blockage on the waste outflow. Empty the wash and use the DRAIN program to get as much water out as possible. From the FRONT of the machine open the lower flap and and then put a large towel on the floor. Unscrew the big black filter cover slowly - some water will come out -about a cupful. Ensuring the machine is turned off, use a cloth to remove any obvious build up of "gunk". Would suggest using an old toothbrush to clean off the surface and the plug.
99% of the time - Job Done!
You may have a blockage in your waste pipe. (If using an extension check any coupling has not "bunged up".
Last, check your waste pipe / grey water connection. Again, this "should" be fine, but it may be bunged up, especially if it feeds into the sink outflow.
Stick back together, plug in and use the 11, fast wash option in cold. Should now be happy, and you should hear water gurgling away noisily down the waste.
Always worth doing a 2 - 90 extra hot wash once in a while even EMPTY of washing just to "flush the system" now and again.
Hope this helps and saves you a £104 service engineer call from indesit :)
Posted on Mar 10, 2010
rickyrt441
  • 4399 Answers
SOURCE: Hi, I own an Indesit
Thanks for using FixYa and welcome to the site. If this is a newer model, I know you can't get any codes. They did this so their electricians can come out to fix it I believe. If you don't have a code, please tell me exactly what the washer is doing besides the lights. Not spinning? Stopping during cycle? Thanks.
Posted on Apr 18, 2011
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
I have got Indesit WIXL 123 washing machine. Until yesterday, it was working fine. But today, when I started it, just after taking water and 5 initial spins, its Door Lock LED and 4th Function Button...
i had the same problem its the motor you need a new one luckly my father inlaw is a scrap collector and i come across a spare washer and salvaged all the parts and i tried plugging a new circuit board but still the same so i tried changing the door lock mechanisim but still the same, so itried just for the hell of it the motor and weyhey we have life i thought the motor was the most unlikely thing to cause the problem but im happy but for how long? next year will replace it with new washer.
Oct 26, 2009 | Indesit W 123 Front Load Washer
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Jan 25, 2008 | Indesit WA 115 Front Load Washer
Jan 04, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
