Question about Brother HL 5140 Laser Printer
Yellow toner light and red status light on - won´t print. I had printed a few pages front and back turning paper over by hand
    President:
  • Brother Master
  • 1,447 Answers
Change your yellow toner insert new toner cartridge then solve your problem
Posted on Jun 23, 2009
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
Nothing else for it with your, take the drum and toner out and check for bits of paper.
Mar 11, 2017 | Brother HL-5370DWT Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the light turns green. however, when i print a file, the file goes into the print queue for a few seconds then...
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Nov 25, 2009 | Brother HL-5240 Laser Printer
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
Jun 17, 2008 | Samsung CLP 300 Laser Printer
B4100 - Yellow Light
U can have stuck a little piece of paper, that it mess whit some sensor. Try to open the Oki, push the drum unit out and watch if there is no paper stucked.
Nov 26, 2007 | OKI B4100 Laser Printer
Brother HL 5140 Laser Printer Logo
575 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
