Question about Oreck XL21 Bagged Upright Vacuum
How to replace the belt on an oreck XL21 vacuum
How is the belt replaced
  • 3 Answers
There's a Pannell on the side onevno2 philips head screw remove that and there is the belt
Posted on Jul 22, 2014
  • 9 Answers
SOURCE: Oreck XL21
You can also set the brush to the middle setting of the special/ normal brush settings. Also, your micro-sweep blade might have popped off making it very hard to push in that direction. The micro-sweep is the plate held by two screws right below the intake with the little blade that sticks up.
Posted on Dec 07, 2007
reddevil6
  • 1673 Answers
SOURCE: Oreck Vacuum troubleshooting
That the bottom plate off, check for a clog in the inlet. If clear, then you probably have a clog in the handle tube. You will have to take the handle loose to clean it out. It may also need a new belt if you haven't changed it for a while, they stretch.
Posted on Feb 05, 2008
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
  • 206 Answers
SOURCE: On/off switch for Oreck XL2600HH
Would have to assume by now you figured this out. However, need to open up the handle. It is a clamshell arrangement. Remove switch from handle, pull one wire at a time from the switch. The electrical connectors are a push-on type. Replace each one, one at a time, to the new switch, and then re-insert switch into handle. Close up the clamshell, tightening all of the screws, but do not strip the plastic housing.
Posted on Oct 19, 2009
Belt too tight to stretch
There are 4 screws on the bottom of the vacuum take those out, then you will have acaccess to the belt and brushroll, lift the brushroll up and out, place the new belt over the pully of the motor and around the brush roll, pull the brush roll as you do it will stretch, replace the 4 screws and it is done
Jun 08, 2014 | Oreck XL21 Bagged Upright Vacuum
Wreck xl21 will not stay in upright position
Your detent needs to be replaced. You can go to Oreck.com and search their store locator to see if there is a repair store near you.
Mar 16, 2014 | Oreck XL21 Bagged Upright Vacuum
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Doesn't pick up
This could be a few reasons. Check and make sure your bag is not full of dirt, a full bag will make your vacuum's suction worse. Next check for clogs of dirt and debris. Check the nozzle and brushroll too. If you find no clogs and the brushroll and belt look good, it may be your vacuum fan is damaged and needs to be replaced.
Genuine Oreck Mataxalloy Fan Impeller R0008
GoodVac.com
800-775-6586
May 09, 2012 | Oreck XL21 Bagged Upright Vacuum
I have an oreck xl and the vaccum wont hardly push. Is it the belt? The brushes aren't turning when I lay it on it side. How do you replace the belt? If you can give detailed instructions I would so...
On the side of the head you'll see a removable plate with one screw. Remove the screw and slide the plate towards the front until it's off. You'll see the belt.
Nov 05, 2010 | Oreck XL21 Bagged Upright Vacuum
Latch pin keeps spinning off belt door?
The only correct solution is to replace the door. A small piece of tape works well too
Apr 30, 2010 | Oreck XL21 Bagged Upright Vacuum
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
Vacuum hard to push
you probably have a broken belt. replace it
Mar 07, 2009 | Oreck XL21 Bagged Upright Vacuum
Burning smell and not picking up
check for blockabe in bag inlet area, or bottom of unit by intake pivot.
ez check is to feel if bag blows firmly up with air when on, if not, you have a blockage.
Nov 02, 2008 | Oreck XL21 Bagged Upright Vacuum
Lost instruction book
remove screw on side of unit, slide cover and replace belt with spare on the bottom.
Oct 12, 2007 | Oreck XL21 Bagged Upright Vacuum
Oreck XL21 Bagged Upright Vacuum Logo
53 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
