Question about Logitech Harmony 650 Remote Control
How to reset harmony 650 for 'system error!' ?
My harmony 650 is frozen with a "system error!" display, how to reset?
  • 5 Answers
Had the same issue, fixed it by going into safe mode by removing one battery and then by holding on/off while re-inserting the battery then to get out of safe mode removed one battery then while holding the number 2 button re-inserted the battery and worked like magic.
Posted on Dec 20, 2015
  • 398 Answers
If your remote is not behaving properly, you can reset it. To do so, remove one of the batteries, hold down the All Off button, and reinsert the battery. A message will appear on the remote screen indicating that the remote has entered safe mode. Next, connect the remote to your computer and sync it. The remote should now be updated and functioning properly.
Posted on May 12, 2014
3 Suggested Answers
SOURCE: harmony 659 erroe measage
Call Harmony support. I have the same thing with Harmony 670 and they said it is a hardware error. No fix that I have been able to find. If it is under warranty they will replace it. If not, I don't know what it would cost to repair.
Posted on Aug 12, 2008
  • 89 Answers
SOURCE: My logitech H628 Harmony remote displays System Error a message
Hi!
Unfortunately, system error one is apparently a hardware issue. It means something about the memory being lost in your Harmony Remote. I had to get a replacement Harmony Remote from Logitech but you would have to see if you are still in your warranty period!!!
I hope you are so you can get a replacement!!! =)
-Kennedy
Posted on Feb 28, 2010
How do I turn off closed caption on Logitech Harmony 650?
It depends on which device your trying to talk to. If its the cable/satellite box, press the devices button on the harmony and select which device your needing to turn the closed caption on or off with. Then scroll the pages until you find the "CC" or caption button.
Nov 28, 2014 | Logitech Harmony 650 Remote Control Silver
Tip
To remove back of Harmony 650 - 6 screws
Tip - I had a defective Harmony 650 with the backlight staying on problem. I thought I would remove the back to view the timing crystal. Just note that there are 'six screws' to be removed to get the back off. Four next to the batteries and 2 under a semi translucent piece just behind the LED cover The small piece is attached by some double-sided tape. On it is written 'Harmony Technology'. It has to be carefully pried up so as not to damage it. You will then have access to the two last screws.
on Mar 23, 2011 | Audio Players & Recorders
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
Programming Xfinity/Comcast into a Harmony 650 remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Mar 31, 2013 | Logitech Harmony 650 Remote Control
Can I change the frequency from radio to infrared in order to use the Logitech Harmony 650 infrared remote control
You want to use a Logitech Harmony 650 remote to control an Emerson shelf system, so what's the problem?
Nov 25, 2012 | Emerson EM-MS9700 6 CD-Changer stereo...
Logitech harmony 650 remote doesn't work with old Roku player
I have an old Roku and was able to get the harmony 650 to recognise it. The model of my old Roku was SD since I originally used it on my analog TV. Everything seems to work without having to "teach" the Harmony. The only quirk was having to use the Exit button to go back to a Netflix movie description and again to go back to the channel list.
Jan 15, 2012 | Logitech Harmony 650 Remote Control
Hi!
-Kennedy
Nov 28, 2009 | Logitech Harmony 880 LCD Remote Control
The unit displays the error message "System Error 1" and "1. Disconnect form USB 2. Remove and re-insert batteries". I've done that and can't get error message to go away. The remote seems frozen.
Hey!
I had this same issue and when I contacted Logitech, they told me it was a memory failure and I needed a replacement harmony remote. I was still under warranty so I got a replacement.
I would advise you contact Logitech to see if you are still in your warranty period so you can get a replacement!
-Kennedy
Oct 29, 2009 | Logitech Harmony 676 LCD Remote Control
Harmony 659 erroe measage
May 21, 2008 | Logitech Harmony 659 LCD Remote Control
Logitech Harmony 650 Remote Control Logo
802 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
