Question about Toshiba Computers & Internet
Code master TOSHIBA MQO1ABDO75 - Toshiba Computers & Internet
  • etrc_new May 15, 2014
    Hi Simohamed Tazi Tazi, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
I have a radio shack 15-302 rc and I need codes for a Toshiba DVD player and a sansui platinum plus t.v. if possible thanks
its not likely you'll find these codes as few ever publish them as manuals have become a thing of the past on most devices.
but you have a search function on any remote it might only give you the power on / off an if your lucky the vol control advanced functions rarely ever work on remotes unless you scan them using the original remote into the new master remote
some day i spect there to be a master site with all scanned codes for every tv etc made .. slobber
Sep 12, 2015 | Toshiba Televison & Video
Need master reset code
Toshiba Regza 32RN635D I dont have the tv controler and I lock the option to use the buttons on the pulpit.How is possible to reset this settings
Feb 02, 2013 | Toshiba 32C110U 32 in. LCD TV
I need to take off the bios password
the bios password can be removed by toshiba, they have a master code which will remove the bios password. There is no generic master code that will remove this bios password. It is unique to each machines serial number and can only be removed by them. I am sorry but that is what you will have to do
Steven.
Apr 22, 2010 | Toshiba Satellite M55-S3512 Notebook
Lost four digit code it;'s a Toshiba TV I have a One for all remote I just need the code
Ok here are the master codes for Toshiba, One of these will work for you.
Toshiba 0 1 5 4 ,0 1 5 6 ,0 0 6 0 ,1 2 5 6
Kindly rate my help++++Thankis for using FIXYA
Feb 07, 2010 | Toshiba 50H82 50" Rear Projection...
Blocking active code
hello i have a manual if you want me to send it to you i'll send it for free
regards
shaun
Jan 21, 2009 | Toshiba CZ19T31 TV
Pioneer dvd-rw dvr-k17a
Are these drives you have fitted yourself, or been added as after market drives?
If so you have run in to the odd way Toshiba set their optical drives as master or slave, although this is generally and IDE #1 error.
To fix this you need to solder pin 45 and 47 together.
47 is the key pin here, as it controls whether the drive is in SLAVE or MASTER mode.
grounded, the drive is in MASTER, open, it is in SLAVE.
pin 45 is simply a grounding pin.
So you'll need to open up the drive, turn it over, and put a small blob of solder on the two pins next to each other - 45 and 47.
If they are original drives or used to work then uninstall the drives and the IDE controllers in Device manager and reboot, letting windows redetect and install the hardware. Also try reinstalling the motherboard drivers available from Toshiba's support site.
Oct 08, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
I cant remember the password to get in to my laptop, is there a code to over ride it.
I have the toshiba master code key generator. I need all the numbers from the laptop. Get back to me. geokohler@gmail.com
Jul 30, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
101 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
