Question about Canon Pixma MP250 All-in-One Color InkJet Printer Scanner Copier Photo
Paper Jam Error message. No visible paper jam. error message continues. what next?
Paper jam message continues even though no visible paper jam. error message continues even after unplugging machine and data cord. What is the next step to resolve?
thumu
  • 69 Answers
SOURCE: False Paper Jam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue .
To isolate the issue, I recommend you to perform below steps.
Steps are:
1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet.
2. Check thoroughly in Printer that there is no small piece of paper in the Printer.
3. Let the Printer be disconnected and idle for 5 minutes.
Meanwhile please perform further steps on Computer.
  Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in  your PC
  Steps are:
 Perform the below steps to restart the print spooler :
1. Click Start>Run
2. Type services.msc
3. Click OK
4. A Window will pop up with so many services listed.
5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart"
6. Restart the Computer.
Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Oct 20, 2007
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
  • 42 Answers
SOURCE: error/paper jam stuck on, despite clearing paper
Micro switch is sticking or damaged. the Yeti
Posted on May 20, 2009
SOURCE: constant paper jam error message
How to fix my Pixma 3300, ink tank is full, please give me ways how to reset.
Posted on Jun 16, 2009
SOURCE: Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Posted on Sep 13, 2009
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
https://www.youtube.com/watch?v=SqWNFVIR6JA
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
Paper jam error message
On mine you have to take the duplexer out of the back of the machine to convince it there's no jam. On the 4350 you press 2 buttons on the sides of the duplexer and it slides out. Look at it, scratch your head and then push it back in. Magically the paper jam is cleared.
Apr 05, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Message shows paper jam even though there is no jam
take all the paper out make sure there is no dirt or dust in the corners,then unplugg the machine for 30 sec. power back up and reload the paper
Feb 26, 2009 | Office Equipment & Supplies
2575 paper jam
This worked for me. If "Paper Jam" error message continues to appear after jam has been cleared, turn off power to printer. Navigate to Control Panel - Printers, right click on HP Photosmart 2570 series icon, click on Delete on drop down menu. This deletes printer from your system. Turn on power to printer. Printer will re-install (may need original installation disc, may not). "Paper Jam" error message should no longer appear.
Mar 27, 2008 | HP Photosmart 2575 All-In-One Printer,...
Paper jam, and check film error messages
dear sir the film sensing sensor and paper path sensors are abnormal or dusty pleaz check them
Sep 19, 2007 | Panasonic KX-FP121 Plain Paper Thermal Fax
Paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Feb 04, 2007 | Canon Image Runner 1630 Copier Copier
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Canon Pixma MP250 All-in-One Color InkJet Printer Scanner Copier Photo Logo
13 people viewed this question
old marine
old marine
