Question about Tecumseh 5hp Engine Snow King Mtd Blowers Lh195sp67517
Adjust governor Adjust the governor
    Loyalty:
    Visited the website for 30 consecutive days.
  • Tecumseh Master
  • 1,430 Answers
Go to PartsTreeRepairClinic they have a video you can look at
Posted on Apr 29, 2018
Tecumseh motor is stuck on high idle. The throttle is on low, but it idles very high. I tried bending the governor linkage and moving the governor spring up and down.
the governor lever near the engine has an adjustment
try looking on
youtube quite a few demos of how to adjust a govenor
Jul 01, 2016 | Tecumseh Garden
How to adjust governor on a Tecumseh hmsk80?
Static Governor Adjust.
With the engine stopped, loosen the screw holding the
governor clamp on the governor lever. Rotate the clamp in
a direction that will force the throttle shaft open and allow
the governor follower arm to rest on the governor spool.
Push the governor lever connected to the throttle to the
wide open throttle position. Hold the lever and clamp in
this position while tightening the screw.
Feb 27, 2015 | Tecumseh Garden
My 1811 cub cadet only idles at one speed, mid range
The correct way to adjust the governor, if this is the problem, is to loosen the set screw at the bottom, then adjust to an idle by rotating the linkage arm , it should try to self center. There may be a problem internal with either a broken arm or Governor thrust pinion.
Dec 16, 2014 | Cub Cadet Garden
How to adjust the governor on 13.5 briggs & stratton intek engine?
First make sure the throttle lever is on full speed position then unloosen the bolt that holds the governor lever to the shaft which protrudes from the engine then with plyers turn the shaft the same direction that the spring pulls the governor lever until it stops then tighten the bolt the holds the governor lever to the shaft. Sometimes the governor shaft might have a screwdriver slot in it to turn it.
Jul 11, 2014 | Briggs & Stratton Governor Spring 691817...
Governor on briggs 445677
Looks like your governor crank broke. Go to www.parttree.com
Apr 09, 2014 | Husqvarna Garden
Governor settings for 18.5hp B&S single cylinder,31E777-2439-B1 Husqvarna
The governor shouldn't need to be adjusted unless it has been bumped or removed. But, if your sure the problem is the governor, you adjust by moving the governor arm in the direction that opens the throttle valve all the way open. Remove air cleaner and filter to inspect while doing this to make sure. Then note that direction, keep in this position, then loosen small nut on governor linkage at base of unit. With a needle nose pliers, turn small center shaft of governor linkage(the part that leads inside engine) in same direction you moved the linkage in earlier step. While holding in place tighten small jam nut. This is called a static set, which is a factory standard. Also, make sure throttle cable is in wide open position when doing this. Good luck.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Feb 16, 2014 | Garden
Honda gx160
Kescorpio56:
Check your throttle and choke settings. Something is causing the throttle plate in the carburetor to remain open or the governor is improperly set. I would reset the air/fuel mixture screws to one and a quarter turns out and back the idle screw all the way out. Make sure that the throttle cable operates the throttle properly and check the governor setting and reset the governor setting if needed. Start the engine and adjust from there. When the engine starts, adjust the idle screw until the engine idles. Adjust the fuel/air mixture screws for the best idle. Then run the RPM up and adjust the fuel/air mixture screws for the best run/idle combination. Don't forget to adjust the governor if the engine runs too fast or too slowly.
May 31, 2013 | Air Tools & Compressors
My coleman started running at a super high rpm. I know it's the governor, but how do I adjust?
It sounds like the governor arms internally are broken, can you feel any resistnce? if not then it will need a tear down to fix
Nov 06, 2012 | Coleman Powermate Subaru 5000W Portable...
Setting the govener
You should not be messing with the governor. The governor wants to slow the engine down. See which direction the throttle shaft needs to travel in, usually from the carb to the governor, to close the throttle butterfly, NOT the choke plate. Loosen the governor clamp, rotate the shaft clockwise while holding the governor in the same direction. Use your head to determine how to make these things happen while tightening the governor nut back up. The engine shouldn't race, and the throttle cable should now work. I shouldn't have told you any of that. Ok, here; if your motor blows up because you do something wrong, I TOLD you not to mess with the governor BEFORE I explained how to adjust one. But that's how you adjust one.
Jun 09, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
1992 Ford F250 - fuel injected motor - running too rich
you cant adjust fuel on the ford governor its fixed.you can adjust fuel on cummins governor.have your governor injection timing check .make sure air filter not stopped up or restricted.it will cause it to run rich.
May 16, 2009 | 1999 Oldsmobile Alero
Tecumseh 5hp  Engine Snow King Mtd Blowers Lh195sp67517 Logo
150 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
