Question about Maytag Dryers
Remover lower access panel maytag 3000 series dryer
SOURCE: How to remove a back panel of maytag neptune dryer?
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Posted on Sep 07, 2008
  • 4 Answers
SOURCE: remove front panel of maytag MDG7400Aww gas dryer
You have to remove the front panel first to access the clip that holds the front of the top down. Instructions:
crosstip medium screwdriver
1/4 inch socket
5/15 inch socket
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  4. This has exposed the interior.
Posted on Nov 01, 2008
danromarris
  • 101 Answers
SOURCE: My Kenmore 90 series dryer won't heat
The thermal fuse is going to be located on the heating element housing. When you take off the front panel you will see your lint screen housing. You will need to remove that to get to the element housing. Once that's out of the way the thermal fuse should be right on top of the housing. It is small and has two small wires coming off of it. The wires should be different colors. Just don't get it mixed up with the thermostat. Just match it up with the new one that you have. It is held in place with two small screws. Let me know if you have any other questions or still can't find it, also let me know if this was helpful. Good luck and glad to help out.
Posted on Jan 22, 2009
SparkyNZ
  • 43 Answers
SOURCE: Just bought a Maytag 3000 washer and dryer and
Most likely the metal is aluminum or stainless and you should worry about rust unless you wash your clothes with salt-water (seawater. not gonna happen.)
If you're really concerned, I'd attempt to reach a maytag customer service person.
800-462-9824
To reach a real person press 0 at every option. Should take three times.
Posted on May 11, 2009
SOURCE: what stacking kit do i use for maytag 3000 series
stack kit #38005
Posted on Dec 29, 2009
Magtag series 3000 Error F 71 Flashing. Will not respond to shut-of or start.. What do you do?
Hi, F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
May 15, 2011 | Maytag Washing Machines
I need to take off the lower front of the dryer unit to gain access to the igniter
Just remove the control panel. The screws are accessible from the drying cabinet. There will be 5 screws holding the bottom panel in place from the top. It tilts out then up off the clips.
Sep 08, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Open front panel on maytag Sde3606ayw?
there are 2 screws near the floor below the door that will let you access the lower front area,then you can remove the door assy and finally the top cover if necessary
Apr 19, 2010 | Dryers
Screen reads CF1, and does not work
Maytag 3000 series .Dryer screen reads CF1, then CF2... then Cf3 and does not work
Apr 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag mce8000 ayw. Want to remove plastic cover
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). After you remove the control console, the screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is the housing that leads to the exhaust blower. Just clean out the mess & reverse the process to replace the parts.
Feb 14, 2010 | Maytag Dryers
Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
Dec 04, 2009 | Televison & Video
How do you remove the top off of a maytag neptune dryer 5500 series?
Take off the 4 phillips head screws around the door. the 2 sides will fold out, pull and the bottom panel will follow. after you have removed the panel you will have access to the frame. you will need to remove the top 2 5/16th screws. you will then lift the top panel and have a access to the top of the drum.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Jan 21, 2009 | Maytag Neptune MCE8000AY Electric Dryer
How do you access the blower wheel on a maytag stackable dryer. I have the LSG7800AAW, the housing is on the lower left but after removing the four hex screws the housing does not come off. Can anyone...
after removing te front panel you can see the blowe rwheel inside hte housing, probably 6 1/4 hex screws holding sheetmetal face on housing as well as to 5/6 hex screws holding motor down
Dec 03, 2008 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
56 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
