Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46 Logo
A
Anonymous Posted on May 12, 2014
How to replace the steering gear on a Husqvara YTH 180
3 Related Answers
Anonymous
  • 6 Answers
  • Posted on Sep 19, 2010
SOURCE: RE: YTH 1946 The gear on
try sullivans garden machinery they should be able to source these parts for you. Their contact info can be found on their website http://www.sullivansgardenmachinery.co.uk
Anonymous
  • 910 Answers
  • Posted on Jun 12, 2011
SOURCE: YTH 180 46" mower deck
There aren't any after market decks for this but it does appear that the original part has been superseded by a replacement so maybe this has solved the problem (see link below).
http://www.superxpower.com/pages/OemParts#/Husqvarna_Power_Equipment/YTH_180_(954140010B)_(1996-12)/Mower_Deck/4018040005/18040031
although you could get cheaper and maybe worth a quick search to compare prices.
http://www.mowpart.com/advanced_search_result.php?keywords=532176026&osCsid=t2du52sd4fgtb5gqm834f3hbg0
Andrew White
  • 2239 Answers
  • Posted on Aug 10, 2012
SOURCE: Husqvarna YTH 180 transaxle fluid
If it is not leaking there should be no need to add oil, if it does not have an external resivoir you would fill throught the filler and leave a 1/4" air gap to allow for expansion.
Yth 2348 seems to have toed out its front wheels so much that it's difficult to steer. The steering gear & sprocket seem fine. Where's the problem?
I have seen this on several mowers. From what I remember, there is no adjustment on the Husqvarna 2348's. There are only a couple parts in this equation, the gear plate, right/left hand spindle arms, and draglinks. Most likely, a draglink or spindle arm is bent slightly. Hope this helps.
Jun 14, 2016 • Garden
Can I swap the engines from a Husqvarna YTH 180 to a Husqvarne YTH 1848XP?
Yes its called measuring everything, then modify to qualify
1helpful
Can I swap the motor from a Husqvarna YTH 180 and put it in a Husqvarna YTH 1848 HP?
The 1848 uses an 18 HP Twin cylinder engine. Mine is a Kawasaki but a similar 18 - 21 HP Kholer will also work. Can't see a problem
What type of fluid goes in husqvarna yth 150?
Hydro gear box takes a sae 20w 50 motor oil, Tuff Torq takes a sae 10w 30 motor oil
2answers
Transaxle fluid for Husqvarna YTH 180
Call your local lawn mower repair guy.... I don't think sewing machine experts will be of much help. :)
1helpful
I have a Husqvara 550 chainsaw. After chain popped and I put it back on, the chain won't move. It's on the gear and everything. Is there a brake or something preventing the chain from mov
There will be a chain brake, grab the brake handle and pull it firmly back to the top handle, this should didd engage the brake, if the chain has de railed the drive lonks will have burs on them which will make it tight in the bar, you need to file all these burs off.
RE: YTH 1946 The gear on the bottom end of the steering shaft is badly worn and steering is difficult. Where can I order a replacement?
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
