Question about Bush Televison & Video
I have a 10 inch portable dvd player with a screen impact fault how do i go about having it fixed
Item cannot be used screen lights up and has a black splash at side
    Genius:
  • Bush Master
  • 1,039 Answers
What Is a screen impact fault. If the screen is cracked it can only be replaced. Most cases it's cheaper to replaced the tv.
Posted on May 12, 2014
Benimur
  • 6966 Answers
SOURCE: setting up tv sound to come thru stereo speakers
Offhand, your Philips 32PFL7422/98 do not have regular Audio Output RCA jacks (white and red), sorry. However, right before the antenna connector is an S/PDIF output connector. This should allow transfer of digital audio signals from the Philips 32PFL7422/98 to a S/PDIF capable receiver or amplifier. If you would look at the rear of your stereo and determine if it has such an input, then it would be a matter of getting the right cable/connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
  • 4102 Answers
SOURCE: Re: 8" Portable DVD Player
HI, the problem you are having is a very common problem with all portable dvd players and also all flip and slide phones and laptops and netbooks.
basically anything that has a screen that flips or slides open will get this problem, now whats causing you the problem is each time you open and close the screen this causes the data ribbon that connects the screen to the circuit board to bend, its made to do this so it always keeps a connection with the screen at all times, but what happens is that over time and use the single strand copper wires running inside this ribbon become brittle and then this either breaks or causes a weak connection like you are getting with yours, now if this was a mobile phone it would be an easy fix as its a common fault so most phone shops stock this part and will fit it for next to nothing, but as yours is a portable dvd player then this makes it a bit more difficult as these are made to be thrown away when they go wrong, which is a waste as most can be repaired, the problem is getting the spare parts is near impossible unless you can get a damaged player to get the parts from or if by some chance your local tv repair shop may have a part that matches up with the ribbon on yours.
these ribbons are cheap to buy but you may struggle to get one, the best thing to try is find your nearest tv repair shop and take it to them and ask them if they can get the ribbon for the screen or if they can match it up with another part.
their is no easy fix you do need to get this part replaced as it will only get worse the more you open and close the screen, try tv repair shop as this is your best option but failing that you will struggle to get the part unless you can buy a damaged player off the well known auction site and hope that the part you need is ok.
let me know how you get on or if you need further assistance ok
Posted on Nov 20, 2010
  • 73 Answers
SOURCE: have a philips pet800 portable
Probably this might be a battery issue, please check whether the battery is perfect or not.
Posted on May 13, 2011
  • 910 Answers
SOURCE: portable dvd player model sd-p1880se,fault
There's no internal fuse and according to the Service Manual which can be downloaded from the link below the solution is to replace the Main PCB.
http://elektrotanya.com/toshiba_sd-p1880se_sm.pdf/download.html
Parts List and Exploded Diagram at the lnk below shows the Main PCB as Part No. AH301676
http://www.brelect.fr/ve/SDP1880SE.pdf
Main PCB can be purchased from the links below although not really viable due to cost.
http://www.encompassparts.com/products/?AH301676
http://www.partstore.com/Part/Toshiba/Toshiba/AH301676/New.aspx
http://www.searspartsdirect.com/partsdirect/part-model/Toshiba-Parts/Video-equipment-Parts/Model-SDP1850SN/1100/0332005/50029536/00001
http://bestbuy.partsearch.com/Model/Toshiba/Toshiba/SDKP19SN.aspx?p=1&z=25&c=0f785d2f2f8522e8a1201a8c0b79050b&bs=Category&bd=Asc&ms=Category&md=Asc&k=&on=
Posted on Jul 30, 2011
SD Tech
  • 14553 Answers
SOURCE: What's your problem?I have a 32 inch rca flat panel dvd player combo , turns on , but no sound and flashes a screen once saying please wait then goes black????
A complete model number would help with giving advice or an answer.
Posted on May 01, 2012
I have a Sylvania 32 inch DVD not reading the DVDs what's wrong???
How To Fix a Portable DVD Player That Is Not Reading or ...
? 17:12
https://www.youtube.com/watch?v=ucNedtR256g
Jan 18, 2015 - Uploaded by orly lando argallon
How To Fix a Portable DVD Player That Is Not Reading or Loading Discs. ... 2:32. How To Clean A DVD ...Missing: inch
Amazon.com: Sylvania SDVD9805/SDVD9805-C 9-Inch ...
www.amazon.com/Sylvania-SDVD9805-SDVD9805...
Amazon.com, Inc.
Rating: 2.9 - ‎916 reviews
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player. Sorry .... 5.0 out of 5 stars32+ hour car trip ... One remote does not work on both, only works for the one it came with. .... Garbage, 3 months in the first of the two DVD players stoppedreading the DVD's so we only used the one and now 5 months in the ...
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen ...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player at Amazon.com. Read honest and ...
Jan 20, 2016 | Sylvania Televison & Video
D1708ES - 7 Inch Portable DVD Player
do you get any sound? how about flash a light at the screen and see if you can see any video. if you get sound and video on the sceen but has not light then either your light is bad or the p/s goin to it. if it is completely dead, then you should be able to test it by pluggin it into a power supply. if its still dead then you may have bigger problems. if you want to continue into it, please let me know. also let me know what you see.
Apr 14, 2008 | Televison & Video
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
Jan 10, 2016 | Coby Televison & Video
How to i make the secreen not be a negative color
Coby TFDVD9952 9" Dual Screen Tablet Portable DVD Player
www.bhphotovideo.com/.../Coby_TFDVD9952_TF...
B & H Photo Video
Rating: 2.5 - ‎2 reviews
Buy Coby TFDVD9952 9" Dual Screen Tablet Portable DVD Player features ... Get up to 2.5 hours of wireless use using the included li-polymer rechargeable battery ... Frame-by-Frame Playback, Not Specified by Manufacturer ... Color, Black.
Amazon.com: Coby TFDVD9952 9-Inches Portable DVD ...
www.amazon.com/Coby-TFDVD9952-9.../B004IZN3...
Amazon.com, Inc.
Rating: 3.1 - ‎17 reviews
The Coby TFDVD9952 9 inch Dual Screen Portable Tablet allows you to watch DVDs on two 9 inch widescreens (16:9) simultaneously. ... Color Name, Black ... When I bought a new one I decided not to get the DVD system factory installed.
Coby TFDVD9952 Car DVD Player - 9" LCD - 16:9 ...
www.overstock.com > ... > Mobile Video
Overstock.com
Rating: 4.5 - ‎4 votes - ‎$172.43 - ‎Out of stock
Get free shipping at Overstock - Your Online Home Theater & Audio Outlet Store! ...The Coby TFDVD9952 9" Dual Screen Portable Tablet allows you to watch DVDs on two 9" widescreens (16:9) simultaneously. ... This player has features not so common in this price range like Dolby Digital for simulated ... negative title.Missing: color
Jan 08, 2016 | Uniden COBY TFDVD9952 9 DUAL SCREEN TABLET...
I have a Craig portable DVD/CD player. It stopped playing sound. What's wrong? Not on mute.
Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote
www.amazon.com/Craig-9...Portable.../B007S71NHM
Amazon.com, Inc.
Rating: 3.3 - ‎58 reviews
Amazon.com: Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote, Black ... But keep in mind this player does not provide the highest quality in portable DVD players one can find. .... The remote stopped working within a few weeks.
Craig 10" LCD Portable DVD Player with Swivel Screen and ...
www.qvc.com/Craig-10-LCD-Portable-DVD-Player-with-Swivel-Sc...
QVCThis 10" portable DVD player from Craig comes with everything you need to help keep ... Plays DVD, CD, CD-R/-RW, JPEG; 10.1" diagonal TFT display; swivel screen design..... Couldn't start DVD unless I held down the door or it would stop.
Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD ...
www.walmart.com/.../Craig...Portable-DVD-CD-Player.../33846...
Walmart
Rating: 3.5 - ‎18 votes - ‎$59.78 - ‎In stock
Buy Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD Player with Remote Control at ... I had one of these portable dvd players but paid over $100.00.
Dec 28, 2015 | Craig Televison & Video
I have a proline dvdp920w ,the fault is the screen goes white the sound still plays
Screen goes white maybe moisture and condensation problem. But may have something to do with contact resistance on the 220 volt supply for LCD tin oxide. Contact resistance need an impact to shift the contacts to restore low resistance contact. Have experience to restore white screen by gently pat the sides of the device.even though Its a cheap fix; but use a fan to lower moisture in your room will fix it permanently.
Nov 21, 2010 | Panasonic DVD-LS55 Portable DVD Player...
My Tru Tech portable dvd player is only a year old and just quit working. When you insert a dvd, it comes up with it's typical, ''loading''. Instead of going to the movie it just satays on the loading...
It's a wonder that DVDs (or even CDs) are read at all; the positioning mechanisms reading them have to deal with millionths of an inch precision and anything can upset the alignment of them.
You might try cleaning the path of the laser with a simple 'cleaning disk' you can buy at electronics outlets. They are not expensive (<$10 US) and can sometimes restore operation by removing dust from the light path. If this doesn't help, I'm afraid you have just another Chinese dumpster item since the repair costs will likely exceed the replacement cost.
Jan 24, 2010 | TruTech PVS12701 Portable DVD Player
Cracking on side of Screen
No warranty for cosmetic problems in general. Is the unit working?...accordianman
Nov 23, 2007 | Mintek MDP-1815 Portable DVD Player
Portable dvd player now plays only black and white
Changing then power source is not going to help you ,you can call polaroid at 1-866-289-5168 and tell them the symptom,they should have an answer for you.
Sep 23, 2006 | Polaroid PDV-1008N Portable DVD Player...
Televison & Video Logo
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
