Question about Pitney Bowes Postage Meter DM500, DM525, DM550, DM575 formerly 620-1 - Ink Cartridge, Red
Pitney bowes problem
Error code "paper in transport"
leroyal
  • 2120 Answers
SOURCE: Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
Posted on Jan 31, 2009
  • 18 Answers
SOURCE: New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
Posted on Aug 24, 2009
  • 149 Answers
SOURCE: Pitney bowes fax machine model 1630 has 76 error
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
Posted on Nov 28, 2009
  • 149 Answers
SOURCE: 9720 Pitney Bowes Fax - access code has mysteriously been placed
Function 9, access code is 9720, press yes, press no until you get to set access code? press yes, delete code, press yes, press stop. I don't think this manual in online any more, but you can go to www.oceusa.com, go to drivers and support, and look for 9820 or 9800 series. The programming instructions are the same as this model
Posted on Dec 24, 2009
  • 149 Answers
SOURCE: pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Pitney bowes 9820 fax machine is popping up error 50 check printer what might be the problem
Error 50 is a service error and you will need to contact your local computer repair or go to their site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Pitney Bowes 9920 Plain Paper Fax
C180 says E2 and printer tray light blinks
E2 means paper miss feed press resum button the go to print
Oct 30, 2009 | Pitney Bowes C180 Copier
Error code 050 what is this? PITNY BOWES 9820
This is a defective laser code. The lubrication in the laser has hardened and the laser cannot turn as fast as it needs to.
Oce is the repair people for PB faxes now. 1 800 243 5556
Oct 05, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9820 error message
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
I need an access codes of a pitney bowes 9920 please
9920 is the default code. if that does not work use ***1 tech override code
Dec 19, 2008 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Aug 26, 2008 | Pitney Bowes C180 Copier
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes Postage Meter DM500, DM525, DM550, DM575 formerly 620-1 - Ink Cartridge, Red Logo
35 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Victorman
Victorman
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
