Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
What could be the problem if the mower runs fine but when engage the cutters the 25amp fuse that between the battery and starter blows everytime? only when i engage the cutters.
If just start up it runs excellent but as soon as i engage the cutters the fuse blows..
  • 182 Answers
On the bottom of your engine there's a pulley for your belt. The pot should have wires connecting to it. Check the wires make sure the belt didn't cut it the pot could be bad
Posted on May 13, 2014
  • curtis chappel May 13, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
Bad PTO clutch, replace clutch
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Check for frayed wires on the safety switch for the blade engagement
Posted on May 12, 2014
2 Suggested Answers
mickey813
  • 472 Answers
SOURCE: toro groundmaster 120 model 30612
you may put a wire frome the moter to the fram see if that helps let me know
Posted on Oct 15, 2009
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Fuse keeps on blowing when I engage the cutter deck
Check that a wire has not been cut. Check the PTO clutch wires as well.
Sep 28, 2015 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Blows a fuse every time I engage the cutting deck
it is not supposed to start unless some one is in the seat
now for your problem, if engaging the cutter deck blows a fuse then check the wiring for a wire that is cut or shorting out on a lever that moves when the cutter is engaged
Apr 18, 2015 | Garden
Mower cuts out when cutter engaged
Check your blades for turning. A OTHER REASON COULD BE THE AIR FILTER GOT WET. If got wet. Put in the sun for a few days.
Mar 03, 2012 | Garden
Battery start brush cutter has problem with starter not engaging ?Just making a whirring noise
Your starter gear is not engaging or broken. Check gear.should move up and down freely. Spray with silicon or WD 40. szm230
Apr 14, 2011 | Garden
I have a problem with the charging system or coil on my toro 52 inch lawn mower. I have replaced the 25amp fuse but when i take the postive battery cable off while the mower is running to check if there is...
I had the same problem
1) find your voltage regulator 3 wire- the one at both end
should be your ac voltage around 20 volts the mildell one will be your 13 volts DC go to the batterie or starter with your engine running, if no voltage there check the rotor with a ohmeter the wire at both end for open circuit or ground circuit with the motor off
p.s. the voltage regulator has to be ground
Apr 11, 2010 | Toro Lawn Mower With Toro Power Tools
All the mower will do is click when trying to start. Battery is fine I took out and had it checked
starter solenoid,switch ,starter,fuse, or one of the safety switches--seat,blade engage satety, need to check the wiring or connections but start with the inline fuse than solenoid these two are the most common problem after a dead battery
Feb 02, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My mtd pinto mower engine cuts out when cutters engage - why?
it sounds as if your carb is dirty remove bowl on carb i"ll bet it's it's dirty if so you will need to remove the carb and clean it
May 23, 2009 | Garden
Starter flywheel is not engaging motor
If you blew a fuse you could have a grounded wire someplace. Check the wiring on the solinoid, on the battery, on the lights and anyplace there could have been a bear spot rubbed. If the flywheel does not engage check the flywheel gear on the end of the started to see if it is chewed and worn. These can be replaced easily,
Apr 04, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
258 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
