Question about Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh sg3110dn does not recognise ink
I have just replaced the ink cartridges and all of them are being recognised apart from the blue. When I was taking the old cartridges out I had trouble taking the blue one out and I think something may not be right. I'm trying to flush the nozzles and heads but it takes a long time and I'm not sure it's doing anything. Do you have any advice?
  • 3 more comments
  •  Mike M
    Mike M May 12, 2014
    Hi Eloisa , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Are you getting any error messages? Is there a log of error messages?
    It sounds like you broke the printer.
  • Eloisa
    Eloisa May 12, 2014
    Hi Mike,
  • Eloisa
    Eloisa May 12, 2014
    woops sorry! pressed the wrong button! I'm not getting any error messages. It all seems to be working fine apart from the blue not being recognised. I bought it second hand from a guy and I don't think he'd used it in quite a while so I thought the blue may have dried up and bit and got stuck. It seems to be printing fine, but it just tells me that the blue has almost run out.
  •  Mike M
    Mike M May 12, 2014
    LOL I have pressed many wrong buttons in my time. If I understand what you've said, the printer does not print blue and reports it is almost out of blue ink. You can try using a Q tip and denatured alcohol and clean the area that the ink cartridge meets the cartridge carrier. You can see if there is a "cleaning" cartridge available for your printer. This will force cleaning fluid through the jets. Other than that, there are lots of used ink jets out there for pretty cheap.
  • Eloisa
    Eloisa May 13, 2014
    Ah nice one, I will give that a go later on! I only paid 20 quid for the printer so it wouldn't be the end of the world if I had to get a new one! Thanks for all your help Mike :)
jaylex
  • 417 Answers
SOURCE: ricoh ap3800 error code sc261
Hi there the following is taken from the service manual. Thanks J
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
Posted on Jan 16, 2008
  • 4 Answers
SOURCE: replace black cpu error, how to fix?
replace the PCU (photo conductor unit)
Posted on Dec 05, 2008
  • 161 Answers
SOURCE: On a ricoh aficio 3500n color laser printer
replace the black pcu(drum unit).
the life of the pcu(s) are 15k each(blk & col) .
the machine will work but copy quality will reduce and the error will be there.
replacing the cartridge has nothing to do with this error.
Posted on Jan 16, 2010
joel_baleta
  • 155 Answers
SOURCE: Follow instrctns in right cover to remove
is it a miss feed problem? open the cover on the right cover of the machine then remove the jammed paper. then close the covers
Posted on May 31, 2010
  • 182 Answers
SOURCE: I've moved relatively new ink cartridges between
well sure you can solve this problem and to disable the ink level monitoring utility, and to do so please follow the following steps:
Click start and click on RUN (else type RUN in search box if using Windows Vista or Windows 7)
Type msconfig in the RUN box
Click on the startup Tab on the top right hand side corner of the system configuration utility
Select the particular Ricoh utility in the list of startup items and disable the same (uncheck it)
Click on Apply and Close
Upon System restart you might get an option or warning of system configuration utility please check the box for don't show this message and click on close
That's it, issue resolved
In case you are unable to find the startup utility you may click on the option on the bottom to disable all, this would also help you improve the speed of computer as it would stop unnecessary startup items to load on system startup.
Posted on Sep 23, 2010
Why does my printer not recognise ink cartridges
there is a reset for that that comes with some carts or you can just order the reset mabye
Jul 25, 2014 | Cannon Office Equipment & Supplies
Can you please help me with the error 28113 ricoh sg3110dn
Paper pinch roller is having some problem may be there is a paper jam or Cartridge try to remove all papers then remove the ink cartridge pull out the power wait for some time ,put back the paper without ink and paper
check if the error is changed if yes replace your ink if still there check for any paper jam clean it all properly and start again.
Jul 07, 2014 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Canon mx350
Hello, your error is - U140 The ink cartridge
cannot be recognized.
A non-supported ink
cartridge is installed. Install
the supported ink cartridge.
Please check that you have the correct ink cartridge.
Nov 01, 2013 | Office Equipment & Supplies
Mpc 1500s sc 202 and af 1075 sc 995
are you sure the codes SC202 is ink related and you need to check the covers on the cartridges as the ink has run out...or the head is not recognising the cartridge..
the sc995 is due to a NVRAMM missmatch or failure.. the serial numbers are not recognised.. if you have replaced the controller board it is not correct or faulty. you can get a sd card and do SP5825 to download new details to the new NVRAMM
Jul 10, 2010 | Ricoh Aficio 1035 Copier
Printer cartridge not recognised
if youre getting this message it means that the cartridge is incompatible with the printer why not use a genuine epson ink cartridge replacement ink sometimes ruin your printer or it damage the printer head
Nov 20, 2009 | Office Equipment & Supplies
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Epson DX8400 does not recognise ink cartridge
on the ink cartridges there should be a little gold chip on them if they dont have that then your printer will not recognise the ink my best bet for you is to buy cheep and reliable placement epson ink or you can buy these ink cartriges which have tubes which feed ink into these replacement cartridges and i have got one of these my self and i would recomend these to anyone
Apr 15, 2009 | Epson Stylus DX8400 All-In-One InkJet...
U150 Canon no cartridge recognised
Because these a refills inks the Chip things they are full so you must replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
Then your error u150 will go.
Sep 25, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Ricoh Aficio 2022 All-In-One Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
