Question about Garden
Where is fuel filter on honda hrr216 mower? - Garden
  • 656 Answers
It should be connected inline with the fuel line.
Posted on May 13, 2014
How to adjust the Governor on Honda Engine
Automatic governor. Replace or rebuild carb. Ensure float is functioning properly..
May 30, 2014 | Honda Genuine oem harmony ii hrr216...
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
How to adjest the carb on a honda hrr216 self propell mower
Ron:
If the mower starts easily and runs well but surges, the problem is not your carburetor! There is an arm coming from the crank case that links to the carburetor throttle arm with a small rod (the rod has a spring around it). That is your throttle governor. Loosen the nut where the governor arm meets the shaft going into the crank case, set the throttle to full throttle and using a pliers, twist the governor arm (coming out of the crank case to full open (twisting the shaft in the same direction that the governor arm would twist it when you go to full throttle). Tighten the governor arm nut without changing that setting... don't let the governor arm move or let the governor arm shaft (coming out of the crank case ) move or the setting will be wrong. ( I know... a third hand would be useful to hold the governor arm to keep it from moving). You may have to make that adjustment a few time to get it right.
Mar 22, 2013 | Garden
Honda HRR216 does not start at all ,what could be the problem
Hi arshadmalik5...
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one.
If the mower/weedeater/edger is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
May 01, 2011 | Husqvarna 160 CC Honda OHC Engine 21 in
I recently sharpened my blades and i noticed swirl or circular scalping pattern in my bermuda turf. what might be the cause. my mower is a honda hrr216
Hi
it may be caused by
1. wheels height - check the height of the wheels .
2. different grass hieghts - circles would appear in places where the grass is higher . check your watering system to ensure water evenly spread . consider sand top soling where the grass is higher .
Jul 17, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
