Question about Euro-Pro Steam Generator EP8001 Iron
What can be done about leaking steam?
The handle gets so hot, I wrap it with cloth to be able to hold it.
  • 561 Answers
Ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
Posted on May 28, 2014
Tefal pro express steam generator iron. When in use the handle gets really hot. I have to put a cloth around it to use. Help.
try to reduse the temperature setting first, if it still does the same then the thermal switch mechanism is not cutting off the switch at proper temperature
need to replace the thermal switch mechanism
Oct 23, 2017 | Tefal Irons
Water coming out of steam holes
Either: the iron is not hot enough to heat the water to steam temperature or the internal water-flow valve is leaking so that too much water is getting through. Check the iron is getting hot enough first. If it is then run some de-scaler (as used in kettles) through the iron to try to clean all the passageways. Always ensure that you fully re-flush the iron after de-scaling or you'll damage your clothes with any acidic residue left in the iron.
Good luck.
Dec 04, 2016 | Irons
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Jul 28, 2012 | Bosch sensixx TDA 8333 Iron
Users instructions elitech 2000w steam iron
alas we've had the same problem since day one, just opened it up, must be the boiler unit leaking at the start to emit the steam so the handle gets hot and now the seal is totally gone it will just leak when the water gets too hot
Dec 12, 2011 | Irons
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
Our iron keeps shutting off and on. It then spurts out brown liquid from the iron. It is on my wall and it stains our clothes
the brown liquid is rust from leaving the water in the iron. Always dump the water out when you are done ironing. You need to run a descaler through it. you can purchase descaler online. The shutting off and on could be a loose wire.
Aug 11, 2010 | Euro-Pro Shark GI490 Iron
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
I have an elitech steam generator iron but water does not get hot so no steam (iron works fine)
I have had this iron for 5 months and only been used 4 times. When I turn it on , there is water leaking out of the iron and the handle is too hot to touch after a few minutes
Dec 28, 2009 | Irons
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
297 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
