Lg error code ch 61
Modeltp-c1008fao
    Novelist:
    Champion:
  • 373 Answers
Out door condenser coil temperature too high. Wash the out door coil out with water unit gets stopped up with dirt and this causes the coil to get hotter than normal.
Posted on Jul 02, 2014
5 Suggested Answers
  • 234 Answers
SOURCE: LG error CH 64
What is the model of the unit?
Posted on Apr 07, 2009
hvac1960
  • 2133 Answers
SOURCE: my LG Artcool isn't working
CH61 means Condenser coil temp high due to non cleaning of condenser/over charged gas/non condensable gas.
Clean your condenser coil. If still problem rests, due to non condensable gas also there will be high temp. kHnce remove the gas, flush out the system and vacumize and then do gas charging.
Posted on Dec 10, 2010
  • 89 Answers
SOURCE: I have an error code
Hi, Please open the front panel of the air con and look for the reset button on the electronic board, press it once. the system will initialize, then you will see all the LED lit randomly wait for a second then closed the front panel and test it. thanks
Posted on Apr 24, 2011
  • 127 Answers
SOURCE: The Air Conditioner will not
If you post the make and model number it should be possible to find the manual online.
then you can look up what "CH61" means
Posted on Jun 06, 2011
Error code ch 61
try cleaning the outdoor unit with a hose pipe. the err code is caused by high pressure on the outdoor unit. please also check if the fan outside runs when the compressor is on, if not the fault is probably caused by the fan or fan capacitor being faulty.hope this is helpful.
Mar 04, 2016 | LG Heating & Cooling
LG air conditioner model number LMN095HVT units keep on flashing with error code CH 46 and with no response at all. How can I fix it? Thanks for your help in advance!
ERROR CH46:
Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor.
Sep 01, 2015 | LG Heating & Cooling
CH-10 error code in LG a/c.Modal-LBUC609RSA5
RAC Product: Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Multi Fdx & Multi V text 8
Dec 24, 2014 | LG Heating & Cooling
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
Apr 16, 2012 | LG Dehumidifiers
LG Artcool about 4 yrs old error code CH 05. no heating or cooling. cheers.
CH 5 on these machines indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assy to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts stockist.
Jun 16, 2011 | Heating & Cooling
I have an error code ch 61 on my LG system
Apr 24, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Hi, I ve got a aircon LSZ244VM4 inverter and fault code is CH 61.Iam out of warranty 1 yr and the unit has already been replaced 1 time when it was in warranty.So what should i do now and what does CH61...
Ch-61.Condenser coil over 65°C. Check coil and filters are clean and free from debris, and airflow is OK. Check system pressures for non-condesables
Clean coil & filter. If non condensable gas, remove gas and flush out the system. Vacuum and recharge.
Jan 01, 2011 | LG Heating & Cooling
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Heating & Cooling Logo
266 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
