Question about GolfBuddy Golf Buddy Pro GPS Range Finder
How do i get my golf buddy(World) fixed?.
I broke the glass front
I have a golf buddy world Platinium model, I would like to enquiry if it is possible to replace the glass face for better vision, generally a little scratched up now
probably can bur touch screens are worth almost as much as a new unit
if you get a new unit , prevent scratches by using the plastic protection that you can get for ipads and phones and cut to size
Sep 27, 2016 | GPS
Battery replacement for golf buddy range finder
Ask on Internet , All cell types available , even advises you on different make & types, See if you can get old Battery out of Buddy Range Finder,
Mar 14, 2015 | GolfBuddy Golf Buddy - dsc-gb200 - Golf...
Golf buddy world does not connect to SD and turns off after thirty seconds
no car stated
nor year.
nor what the heck is a golf buddy, Huh?
does this stop car from driving?
Jun 15, 2014 | Cars & Trucks
I have a golf buddy world and after 3 years I'm getting the message that I have no sd card how do I fix it
Mine did the same thing and I found out that the sd card was not fully inserted. It is right beside the power/computer jack. I think I tried to plug in the power charger into the port that holds the sd card and that popped it out. It is spring loaded so you push it in to remove it and push it in to insert it. Hope this helps.
Jan 26, 2014 | GolfBuddy GPS
No SDCARD
First thing to try is another SD card.
May 10, 2013 | GolfBuddy World GPS Range Finder -...
Touch screen not working golf buddy world
Do you hear a beep when you touch the screen? If you do it is more than likely a software issue, or the cameras are misaligned..
Touch screen gps
Aug 19, 2012 | GolfBuddy World GPS Range Finder -...
Left front window fell inside door, vw golf 2000 modal electric windows
Either the glass came off the rail, or the roller came off the rail. You'll have to take your door panel off and see what happened. It's usually an easy fix.
May 21, 2009 | 2000 Volkswagen Golf
GolfBuddy Golf Buddy Pro GPS Range Finder Logo
Top GolfBuddy Optics Experts
 Larry
Larry
Are you a GolfBuddy Optic Expert? Answer questions, earn points and help others
