Question about Birds
Image of orange birf - Birds
  • 2,509 Answers
Ahh the famous Orange Birf! It can be found deep in the forests of the republic of San Seriffe, waking you in the early morning with it's distinctive call...."birf birf birf" Orange Birds Wallpaper
Posted on May 12, 2014
Tiny soft-bodied, bright orange bug bit me. What might it be?
I wonder if it was a red spider mite, but there are hundreds of possibilities.
Red Spider Mite
http://waynesword.palomar.edu/redmite7a.htm
Here are a few more. Look at the images tab as well.
tiny soft bodied bright orange bug Google Search
Mar 28, 2017 | Orange Computers & Internet
Shut off at start up
Hello
Possible memory sticks are either installed wrong or not seated properly.
Or you have them in the wrong slots,most slots are color coded.As seen in the picture.orange yellow orange yellow,shown lower right hand side.
http://www.diycustomcomputers.com/images/MotherboardB.jpg
If you using two sticks each needs to be in either yellow or orange.
Mar 31, 2011 | ASUS P5L-MX Motherboard
Orange blinking light and no image. Fan on but no
make sure the colorwheel is spinneng. if it isn't, the lamp won't strike. if the colorwheel is fine, check the lamp for bulges, black spots, fogging or flaking. replace if necessary. if the lamp is fine, replace the ballast.
Jan 22, 2010 | InFocus LP 530 Multimedia Projector
Orange light( image engine) lit up while driving,
whenever this light is turned on there is a electronic engine control fault code set in the memory of the computer that controlds the system, have the OBD 2 electronic engine control system tested to determine which one of the approx 200 poss fault codes u have stored in memory
Dec 20, 2009 | 2001 Toyota Corolla
Some images 'cool' some 'warm'
That issue is related to "white balance". Sounds like the camera is not measuring white balance correctly in order to determine the best setting for each shot, and is flipping between correct and incorrect settings, even in the same conditions!
I could go into detail here, but really it is much easier and perhaps better explained with images on many websites. Here is one example:
http://www.cambridgeincolour.com/tutorials/white-balance.htm
As for a solution, well obviously the camera is not working as it should, but you could also try setting white balance manually if your camera allows it. The above site tutorial will give you an idea of how to do that and what setting to use.
Jul 20, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
May 10, 2009 | Optoma HD72 Multimedia Projector
Replacement drum for Q3964a
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum Replace the imaging drum
  1. Push the scanner-release button to open the scanner assembly. Figure 1: Example of scanner release button location c00364331.gif
  2. Open the top cover. Figure 2: Example of top cover being opened c00364332.gif
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
    NOTE: The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum. Figure 3: Example of imaging drum rotation c00364333.gif
  4. Lift the imaging drum straight up to remove it from the device. Figure 4: Example of imaging drum removal c00364334.gif
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins. Figure 5: Example of shipping pin locations c00364335.gif
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers. Figure 6: Example of shipping lock and spacer locations c00364336.gif
  8. Remove the orange cover from the imaging drum. Figure 7: Example of orange cover location c00364337.gif CAUTION: Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer. Figure 8: Example of arrow location c00364338.gif
  10. Lower the imaging drum into the printer, and then press it firmly into place. Figure 9: Example of imaging drum installation c00364339.gif
  11. Close the top cover and the scanner assembly.
Feb 27, 2009 | HP LaserJet 2840 All-In-One Printer
DSC-V1 orange image
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Jan 07, 2008 | Sony Cyber-Shot DSC-V1 Digital Camera
Battery Life
Your SD memory expansion card may be damaged.
Try the same procedure without the expansion SD card.
Use the Casio QV-R40 10meg memory with same camera settings.
Dec 16, 2007 | Casio QV-R40 Digital Camera
Birds Logo
249 people viewed this question
Top Birds Experts
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
