Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
How do i set timing gears for a john deere 2020
  • 28 Answers
I'd suggest going to John Deere's website and look up an owner's manual and repair manual . If you have Adobe Reader you can copy it in a PDF format.
Posted on Jun 20, 2014
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
SOURCE: I would like a wiring diagram for a John Deere
I found the diagram.
Posted on Oct 20, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a John Deere 2020 diesel. I can't get the fuel pump off
You need to remove the nut under the cover in front of the pump and then borrow a tool from a j.d dealership to pull the coupler off the pump,you may need the dealer to do this because they have a no lend pollicy for their special tools.Hope this helps.
Posted on Nov 10, 2009
Daniel S
  • 4323 Answers
SOURCE: John Deere Model 445 garden
Hi
Please check for the anti back fire solenoid in the front of the carb. Check whether the wiring to it is fine and if it is getting +12 V. If yes then you maybe required to replace the solenod.
However, if this doesn't resolve the issue then you would need to adjust manually so that decompresser works normally. Inspect the flywheel key as well, it may have sheared.
Check the carb filter and the make sure there is no sign of water in/around the carbeurater. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 05, 2010
Johndeere 2020 engine and balance shaft timeing
Put engine on TDC number one , balance weights will be bottomed in housing , lift it up and it will engage in the right tooth on the crankshaft gear bolt down while holding in place. There are no timing marks on crank gear or balance gear.
Feb 07, 2017 | John Deere Garden
Compression in a 1966 john deere tractor its a 2020
is this a multi cylinder diesel farm tractor or what
remember that questions go global and you have to be specific in details as a jd unit 202 in your country may be a 1212 or what ever in another country
however moving on , if it has more than 2 cylinders , the problem can be a head gasket blown between adjacent cylinders , cracked head or valve problem ( burnt or incorrect valve adjustment)
same ideas apply to petrol engines as well
Dec 15, 2015 | John Deere Garden
I need a good part number for my jd 2020 starter 4 cyl gas
Is it direct drive or gear? We carry both...your talking 157.97 plus S&H for Direct and 235.90 plus 60.00 core fee and then S&H for gear drive...both delco starters. ediesinc@gmail.com for more info.
May 27, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Nov 10, 2009 | John Deere Tractor Side Screen...
I have a JD 2020 1970. The brakes lock up when I
sounds to me like the caliper/piston/cylinder is freezing up on it
try looking at replacement
Oct 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Jun 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 2020 water pump repair?
Hello:
From your Description it Sounds like a Bad Water Pump Bearing and Seal.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 10, 2009 | John Deere Tractor Side Screen...
Clutch problem
Hello:
It Sounds like the Clutch Idler is Bent and Requires Replacing.
A Homeowner can Replace the Clutch Idler Arm and Pulley with Little to No Worries.
You can View a Breakdown of this Unit at the Following Site Addy.
Enter the Model Numbers 2020 and CLick Search. Now Select your Model and then Select Sectional Index.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
232 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
