Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
How do i test the trim sending unit on a yamaha 90 outboard motor
I need to test the trim sending unit to determine if gauge or sender is bad. ignition on gauge goes to up and doesn't move.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
Should go down if you are trimming down ,
Posted on Feb 14, 2016
5 Suggested Answers
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
  • 53 Answers
SOURCE: yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
Posted on Nov 02, 2009
  • 107 Answers
SOURCE: Outboard Motor Boat Bass Fishing Saltwater Base: 1990 yamaha 15 hp oil mix ratio...
100 - 1
Posted on Jul 21, 2010
muffteck
  • 202 Answers
SOURCE: Need a operation manual for a 1975 Mercury 9.8hp
put it in a water barrel and start ck compression ck for bent prop shaft and water in gear case b/4 u buy
Posted on Nov 11, 2011
Fuel sending unit test and replace
Checking and replacing a fuel sender unit ' How a Car Works
www.howacarworks.com/fuel.../checking-and-replacing-a-fuel-sender-u...
Learn how to check and replace a fuel gauge sender unit, and how to check a fueltank. ... Fuel pipe Sender lead Breather pipe Sender unit Petrol tank Filter Float arm Float Mounting flange Filler .... Test by quickly removing the filler cap.
How to test a Fuel Sender - YouTube
? 2:01
https://www.youtube.com/watch?v=hHzeOOzQKR8
Dec 1, 2012 - Uploaded by TheyMightBeRacing
This video shows the basics of how to test a fuel sender to ensure that it is ... Trailblazer fuel gauge not working/sending unit test and replace ...
Trailblazer fuel gauge not working/sending unit test and ...
? 17:29
https://www.youtube.com/watch?v=aIMDauRGwFg
Sep 23, 2012 - Uploaded by MAY03LT
How to replace the fuel sending unit in the 02-03 Trailblazers. I also show how the fuel gauge works and how ...
Toyota Corolla Fuel Pump Removal Sending Unit Testing ...
? 6:17
https://www.youtube.com/watch?v=JtYMRrUpZr0
Oct 29, 2014 - Uploaded by richpin06a
Toyota Corolla Fuel Pump Removal Sending Unit Testing. ...Camry 1997 1998 1999 2000 2001 fuel pump replacement - Duration: 9:32.
Jan 13, 2016 | Cars & Trucks
How to replace the mamuel relief value on a 90 hp yamaha out board motor
You have to remove starboard transom bracket,then remove circling from t/tilt release screw,remove screw,left hand thread.There is a flat washer that normally sticks to screw/valve,this needs to be replaced.Its easier to do this with motor trimmed up or if motor is off boat,lying on its side.Very little oil will come out if done in trimmed up position
Mar 29, 2014 | Light Outboard Motor Boat Bass Fishing...
Trouble shooting an outdrive trim indicator
remove sending unit turn on key switch work sender by hand watch gauge should work evenly very eratic change sender
Jul 15, 2012 | Boating
Gas gauge won't work right when youfill up it shows full but it will not go below 3/4 full. What is the problem?
You most likely have a sending unit inside the fuel tank that is going bad. It takes a little testing to determine if this is indeed the problem but I would say odds are about 90% that it is. If you do discover that the sender is bad and decide to replace it I would also replace the fuel pump at the same time. Some of these senders are sold only as part of the pump module so you might end up with both anyhow. Even if they are sold seperately I would still replace the pump, especially if you are near the 100k mile mark.
Jun 10, 2010 | 2000 Buick Century
Speedo for a 80hp yamaha outboard
There is not a sending unit for this, remove the rubber hose from the back of the speedo and blow back through the hose and out at the motor lower unit. Most engines have a small hole in the front of the lower unit for the water to pass through, it is probably plugged with sand or wood
Jan 08, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
