Question about Kitchen Ranges
How do I stop the self clean on Sears Kenmore Gas Stove
I pressed the wrong button on my Sears Kenmore gas range. The oven started to self clean. I was able to unlock the door by holding the clear button for a few seconds however, the cleaning sound is still going. So I unplugged it. The weather is going to be in the 90's this week so I really don't want to go through the entire cleaning process just so that it will stop on its own when completed. Any advice?
  • Connie Struebing
    Connie Struebing May 12, 2014
    I forgot to say I uplugged it right away when then clear was not stopping the cycle.
  • Connie Struebing
    Connie Struebing May 14, 2014
    I was trying to set the "timer" but hit the "Select clean" by mistake. When I heard the oven make the sound of it cleaning I freaked because I have pots and pans inside the oven... for storage, I have a small kitchen. I plugged it back in and hit the "stop/clear" button ..it did not Stop the clean cycle. So I unplugged the stove. Checked the internet ...said to hold the button "stop/clear" for a few seconds which I did (after I plugged it back in again). I was able to open the door. But the cycle was still going...so I unplugged it for the last time. I've been lighting the burners with a bar-b-q lighter Hot Shot.
SOURCE: Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Posted on May 13, 2009
SOURCE: Range not working after self-cleaning cycle
Hi limit behind oven is open. Replace.
Posted on Dec 23, 2009
  • 5 Answers
SOURCE: Oven door after self clean cycle won't unlock
Both the oven" ON " light and " Clean " light will flash when the clean has finished . When the " clean " light flashes , slide the latch handle to the left as far as it will go , then turn the " OVEN SET " knob to " OFF " to open the door.
Posted on Mar 26, 2010
  • 5 Answers
SOURCE: Self-cleaning oven doesn't work on Kenmore electric oven
I suspect the timer is involved in this process. It can be set to clean automatically. You need to set the complete time at least 2 hours after start.
Posted on Apr 11, 2010
  • 857 Answers
SOURCE: GE oven door won't unlock
Not usually, there may be a problem in the locking mechanism. You must check it out and get that fixed.
Posted on Jul 20, 2010
I do not know how to use the self clean feature on my Kenmore Gas stove
Hi
Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Please post back for any further assistance. Hope this helps...
Daniel
Aug 28, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Gas Range
Hey Alan- 'Self clean' sells. Techs call this function 'self- destruct'. Depending on age and number of previous 'clean' cycles, the control may have developed errors, or lockout switches may not function. If inside is thoroughly scraped, and bottom pan checked, removed, and cleaned if necessary, oven should work fine. Preventitive drip pans and a lot of aluminum foil keep the 'Self Clean' Gremlins away. Hope this helps- Thanks- ED
Feb 25, 2010 | Kenmore 73053 Gas Kitchen Range
Sears Kenmore Gas oven lights and relights
sounds like dirty nozzle,or not enough air to make combustion, the poof sound is when it builds up with extra gas after flame quits,and re-lights there is a bit of excess gas around igniter.
clean nozzle.altho there is lots of safety percautions built in to stove,MAKE SURE LOTS OF FRESH AIR, AND STOVE AND GAS OFF,when cleaning nozzle.
[could be air intake problem to]
Dec 19, 2009 | Kitchen Ranges
KENMORE SELF CLEANING FEATURE WILL NOT ACTUATE
Firstly, empty the oven of stuff, including the little thermostat that dangles from the grate, if you value it's life.
Next, close oven door.
Press CLEAN; it beeps and green LED illuminates. LED readout says " -- -- --".
Press the UP arrow; it beeps and LED readout says: ''3:00'', for a three hour burn.
DOOR LOCKED LED blinks while door locking mechanism actuates, then stays on steady. Burner ignites, and it's off to the races.
The exterior of the Range becomes quite HOT, providing an excellent opportunity to educate young children of the concept. ;)
The Cleaning Cycle can be stopped at any time by pressing the OFF/CANCEL button for ~3 seconds. The door will remain locked until the internal temperature of the oven falls below 400F. Nice toy.
Apr 10, 2008 | Kitchen Ranges
Dec 23, 2007 | Kitchen Ranges
How to use the self cleaning feature of kenmore gas range
I NEED THE BOOK ON HOW TO USE THE OVEN ON THE STOVE RANGE
Nov 18, 2007 | Kitchen Ranges
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
