Question about Vehicle Parts & Accessories
1997 ford ranger won't start
I have spark, I am getting fuel up to the throttle Body. The battery is charged. I have change the starter, all the relays - checks the fuel pump, and change the fuel filter. . . Still won't start -
    Habit-Forming:
  • 72 Answers
What size engine? If it is a 2.3L it may be a slipped timing belt
Posted on May 12, 2014
It a 98 ranger xlt was having idle problems and it pulsated while driving at study speed say 40. I disconnected that sensor by the t.stat and those problems went away. Now dont want to start after running....
Scrape spade to bright metal, clean connector with toothpick put connector back on Clear codes, one way is to leave positive battery terminal off overnight. The brain(ECU) must have the
temp information to start and run. Without excellent connection
It doesn't know what to do.
Mar 13, 2015 | 1998 Ford Ranger
No power to fuel pump
You added fuel and still no start. If you have indeed proved a no spark condition, it could be the ignition box inside the distributor is dead, a common problem with late '80s ford ignitions.
Apr 04, 2014 | 1987 Ford Ranger
I have a 89 ford ranger it won't start it acts
What have you checked so far ?
Is it getting spark to the plugs ?
Can you spray starting fluid into the throttle body and get it to start ?
Have you checked fuel pressure at the injectors ?
Jan 18, 2013 | Cars & Trucks
MY 2004 Ford Ranger engine turns over but wont start.
Are you getting fire?have you checked your fuel filter and coil pack
Dec 08, 2012 | 2004 Ford Ranger
2003 ford ranger wont start, battery and starter are both good relay checks out
assumed battery and starter are good, r u getting fuel and sparks? it need both. if sparks then no fuel, if you get fuel then no sparks. no fuel, bad fuel pump, no spark, bad coil.
Nov 08, 2011 | 2003 Ford Ranger Regular Cab
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
I have a 98 Ford Ranger, 3.0L. I replaced the EGR
i would change your idle air controle its 60$ and a great start
Jan 19, 2010 | 1998 Ford Ranger SuperCab
01 ford ranger 4x4 4.0V6-- rough idle like it wants to cut off. loses power or studders under acceleration. struggles to get up to 55 or 60
I agree. Try replacing the spark plugs, install new spark plug wires, change the air filter, change the fuel filter, and test the battery and alternator. Run a bottle of fuel system cleaner and water remover through it. To replace the spark plugs you'll most likely have to go through the wheel wells cause of their hard accessibility from the top. The fuel filter is located on the inside of the frame on the driver's side. Hope this helps. God bless
Oct 22, 2009 | 2000 Ford Ranger SuperCab
Ford ranger wont start
first of all make sure battery is fully charged auto zone will test batteries for free but if you can get it jumped and running while it is running take the positive side cable off the battery and if it dies then it is the alternator and also look at the condition of the drive belt but if you do all this and the truck does not start spray very little starter fluid in the throttle body if it starts ask yourself when was last time I changed the fuel filter and also have someone to be back by the gas tank to see if you can hear the pump and check out the fuel pump relay which is normally under the hood on the drivers side before changing the fuel pump
Nov 23, 2008 | 2003 Ford Ranger Regular Cab
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
