Dewalt radio dc 010 will not charge
Bought a new battery but the radio won,t charge
  • 2,509 Answers
Check the voltage from the charger, check the socket which it plugs into for fractures and dry joints on the circuit board. Those are the most likely failure points. Have you tried moving the plug around to see if it's a bad connection?
Posted on May 12, 2014
SOURCE: Dewalt Radio
dewalt radio works fine on mains
will not work off battery
Posted on Nov 27, 2007
SOURCE: my used dewalt radio
open up and check fuses
Posted on Mar 26, 2009
  • 51 Answers
SOURCE: Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
Posted on Aug 08, 2009
  • 60 Answers
SOURCE: my dewalt dw911 radio/charger works on either
More than likely your internal charger is faulty. Inside your inernal charger unit check the 2 anmp fuse which is white in colour.
Posted on Nov 28, 2009
  • 60 Answers
SOURCE: my dewalt radio stopped working. I plugged it in,
Check fuses inside. Check fuse and connections in plug. If this is a 110v radio there is one on transformer winding.
Posted on Dec 05, 2009
DW 911 radio works on mains power but not with battery inserted
Change the battery connector pcb board part# 5140019-41 12.07 on ereplacementparts.com
Dec 06, 2014 | Radio Communications
I have an 8560w and it won't charge the battery while plugged in..I bought a new battery thinking that it was the problem and still have the same issue.
your battery is fine. there may be problem with your battery charging adaptor. plz try to replace it or claim it's warranty and get it repaired.
Apr 10, 2013 | Lenovo Computers & Internet
Dewalt lithium battery won't charge
Your problem states you have a Makita tool and your question is about a Dewalt lithium battery. In either case if the battery won't take a charge or if the charger is showing the battery is defective the only fix is to replace the battery. Some causes for defective batteries or batteries that won't take a charge are bad cells in the battery, bad or shorted IC board in hte battery, broken or burnt connections between the many cells or between the cells and IC board or even bad or old cells that will no longer charge up. The time and effort needed to find out what the problem is then finding another battery to scavenge parts from (individual battery parts are not available) is never worth the cost of just buying another battery and going back to work with the tool(s).
Jun 27, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Battery won't charge
battery has gone .. u may need to buy new one ..or interchange the battery wid other set
Jun 14, 2012 | Midland Radio MIDLAND XT28 Two-Way Radio
I have 2 DeWalt Lithium-ion batteries Apprx. 4 years old, charged 3 times...won't charge now
Either bad batteries or a bad charger. You can use a multimeter to test for DC voltage output in the charger.
May 03, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
2003 Chrysler Town & Country, put in new alternator, now have 2 lights on including battery and one looking like a pump. Radio won't work.
Hello
The reason the battery light is on is that the charging system voltage is below the battery voltage, this means the charging system is not working correctly, since you already replaced the Alternator for I assume the same problem, unless you got a defective rebuilt (which is poss if bought from Autozone or one of the other discount parts stores) the charging system problem is not the Alternator but lies elsewhere in the electrical system. Use a volt meter and check the voltage at the battery cables with the engine running at high idle (at least 1000 RPM) the voltage should be at least 13.4 to about 14.2 Volts DC. This is also most likely the cause of the light that is on that you say looks like a pump due to the low charging system voltage. As to the radio it is in theft lock, this happens anytime the battery is disconnected, you will need to enter the unique security code for your radio, if you are not the original owner this may be a problem, as the little card with the code and the instructions to enter it often gets misplaced. You will likely end up at the dealer who can access the Chrysler factory computer and retrieve the code, there may be a charge for this.
Nov 30, 2011 | 2003 Chrysler Town & Country
The low battery light remains on after I changed the battery,
Hello
There are two possibilities for this fault. The first one is with its battery itself. If the battery did not hold current, in otherwords, it has weak, proper charge both in volts and amperes won't hold on it, and when the device draw current from it while it works, voltage drop will occur, and low voltage indication will be displayed.
The second chance is due to the charger circuit inside the radio. If charger circuit do not give proper voltage and current to battery, the battery won't charge to its full capacity.
Check it by replacing it with a new battery [batteries] first. If it helps you it's OK. If not, your radio need service, and its charger circuit must be checked well. OK.
Nov 15, 2011 | Emerson CKS2237 Clock Radio
Our 2007 odyssey the battery died after only one year. Bought new one now four days later car won't start again. We left no lights on or radio, not even the dvd player. What's wrong with this...
Battery might have died cause the altinator is not charging 14+V Please charge the battery, donot boost the dead battery. After charging the battery check the altinator output.
Sep 22, 2011 | 2007 Honda Odyssey
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
 Grubhead
Grubhead
