Question about Canon CanoScan LiDE 80 Film Flatbed Scanner
Canon CanoScan Lide 80 Flatbed Scanner. Scanning arm won't move.
Scanner makes a grinding noise and the scanning arm doesn't move an error message then appears (code:201) saying to consult the manual. I've looked in the manual but can't find the code it's referencing. I checked the scanner lock on the back to make sure it's unlocked which it is, but it appears to be broken as it's stuck in the open position and can't be moved.
It feels to me like it's a mechanical problem, any ideas anyone?
SOURCE: CanoScan LiDE 20/LiDE 30 Mac 10.4.9
This seems to work with fink/xsane or the canoscan drivers from their site, but neither as well as you might like.
Posted on Dec 11, 2007
  • 111 Answers
SOURCE: Canon LIDE 500F scanner does not scan - returns error message about releasing lock switch, detaching interface cable and reconnecting
Check the lock switch and make sure it is unlocked. I think the lock switch is on the bottom...or it may be under the lid near one of the hinges. Flip it back and forth and leave it in the unlocked position.
If this doesn't work, then it will most likely need service. Contact Canon Tech Support.
Posted on May 09, 2008
SOURCE: TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
I had the same problem more than 1 year ago and then found the solution (at least in my case that is) somewhere on the internet. Since I have the same problem with a new computer I searched the internet once more, but did not find the solution. However, last time I was so clever to write down the solution on the disk of my old laptop. The laptop is gone, but not the disk, so I could access it by putting it in an USB enclosure and was able to find the solution once again. Here it is:
c:WINDOWS wain_32CNQLxx (xx is the number of your scanner) should be included in the PATH environmental variable.
Now I know where to look for I found the link where I found it first:
http://www.everythingusb.com/forums/showthread.php?threadid=7337
The entry was by pallosp.
Posted on Nov 04, 2008
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Posted on Jul 04, 2009
SOURCE: CanoScan Lide 25 error message
ok, I solved this problem in an unorthodox fashion but it worked... so far that is. First a little history, I was getting this problem constantly and I was at the point where I was going to dump the machine in the trash... therefore I decided to do a little surgery.
Solution: I ripped off the plastic sides of the scanner and lifted the glass from the front while it was still in the back of the machine. I started to try to scan. After doing that I received a different error. After that error I replaced the glass without the plastic sides and it scanned with no problem. It works for me and it has worked since. Unorthodox? Yes it is, but when I forced a different error and forced recognition. I believe this is a software problem and not a hardware. Good luck to the rest of you. Any questions, I'll try to reply.
Posted on Aug 29, 2009
Canoscan Lide 110 driver
Perhaps you have forgotten to unplug the scanner before
scanning? That's what happened to me. I kept getting
different error codes, 5,202,63 or 5,202,52 or 5,202,54 and
also a message that the driver was not in the TWAIN folder.
According to the help file the problem might have been due
to my nfts file system. I also tried downloading various
new drivers. Nothing helped until I noticed that I had not
unplugged the scanner!
Jun 27, 2012 | Canon CanoScan LiDE110 Flatbed Scanner Inc...
Have no installation disk for canon lide 80 scanner . OS X 10.6 (Snow Leopard)
An error message popping out saying:
release the lock switch, deatach the I/F cable and receoonect.
scanner driver will be closed.
Code: 2,179,0
I have unlocked it and recoonect the cable. but my scanner cant seem to scan through it.
Oct 30, 2009 | Canon CanoScan LiDE 80 Film Flatbed...
Clicking noise scanner stuck
have you checked the scanner lock ? it should be off.
May 13, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Drivers for Canon Lide 25 not working
Where are you scanning from? What application? Did you download and install Toolbox as well as the driver?
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=11463
Jul 20, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Help
You'll have to do that in the software that handles the image after scanning. Do you start scanning from your computer, or direcly on the scanner? While executing the scan from the computer, you can select the save-path there. While executing directly on the scanner you need to to go to the settings of your scanner, i think.
Mar 27, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanner making grinding noise
Please open and apply oil on roller rod as some rust have accumulated on it prohibiting it move.
Jan 01, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Scanning negatives on CanoScan 600F, I get an error message "Cannot write or read. 252.0.0"
The Canon support site is the place to go for that if your Manual does not tell you.
However remove the software and reload it - it may be as simple as that.
Dec 26, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Canon CanoScan LiDE 80 Film Flatbed Scanner Logo
207 people viewed this question
old marine
old marine
