Question about Garden
How to change oil on lawn tractor
Model 917288561
There should be a drain plug on the side. Usually where the oil goes in by the dipstick, it will be a square headed pipe plug. Also check the bottom of the engine for pipe plugs into the case. These will have a recessed square opening that a 3/8" ratchet or extension will fit into.
Posted on May 16, 2014
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
I have a b&s model 330000 engine which seems to leak a small amount of oil on the left side of the engine ans accumulates on the frame rail of the lawn tractor before dropping to the ground. i rec
My guess, without seeing the engine would be a seal or gasket is bad. Use Gunk brand degreaser to clean the engine. Start it up after that with the engine cover off and watch for leaks.
Jun 23, 2014 | Simplicity Regent 22 44 Riding Lawn Mower...
How to change the oil on my lawn tractor, model 917288561
Your model number sounds like a sears craftsmen model and it is equipped with a push and twist drain plug it is black with a yellow cap near the bottom of the engine just above the frame always start ther draining the oil out then remove the filter if applicable and replace. Then fill with oil to the full mark start engine run for about 20 seconds then shut off and recheck oil and fill as needed
May 12, 2014 | Garden
My craftsman lawn tractor smokes when I start it and it is blowing oil out. What is causing this?
check the oil and see if it smells like gas the needle valves int he carb have had alot of problems seating and gas over flows into the crank case change the needle and seat and change the oil
Jun 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42" lawn tractor model 917.272082,
some of these have oil sensors.. you could bypass it just to check if this is the problem .. check the oil !! there is a solenoid on the carb also that shuts the gas off..jay
Jul 23, 2011 | Craftsman Garden
What type of oil do I use for Craftsman 42" Briggs & Stratton 17.5 hp Gas Powered Riding Lawn Tractor for oil change
Only use SAE 30 if using conventional oil. Briggs is real specific about that. I highly recommend using synthetic oil in ALL lawn equipment. You can use a multi-viscosity oil like SAE 10W-30 if you use synthetic, but straight 30 weight if using conventional. The brand is up to you.
Jun 08, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oil change
may not have one, need to change oil more frequently, ie. more than once a season like you most likely would for an engine with a filter
Jun 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro lawn mower
You may have overserviced the oil.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Changing the oil filter on a lawn tractor
If it is a screw on type oil filter, apply a film of oil on seal, then screw on. If you want to, go ahead and pour some oil in the filter, in my opinion the oil will circulate faster if there is some oil already in the filter.
Apr 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman ys 4500 lawn tractor change oil indicator won't go off
Being a reminder light it should reset itself after engine run hours increase from the programed reminder time
Jun 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
