Hi, I have Sony tv model kdf-e55a20 projection type. Trouble is when tv is turn on by power switch 6 blinking green led steady then turns to solid green video and sound come on and fan is working after 1 minute tv turns off by iself no led lights at all.Then I press power switch to start again after a minute shuts down.No red blinking led lights come on no lights at all
  • 1 more comment
  • spollaro Jun 23, 2009
    need more information to solve my problem
    hi, I am technical person where is the problem on what board inside tv is the transistor and diode. could it be weak lamp because push power switch hear click of relay to start the tv and it works for one minute then shuts off.
    I need more information from expert
  • 10,594 Answers
Hi, I am technical person where is the problem on what board inside tv is the transistor and diode. could it be weak lamp because push power switch hear click of relay to start the tv and it works for one minute then shuts off.
Its weak Lamp symptoms. You will see lamp LED red if lamp is broken or ballast supply does not work. In this TV ballast try to fire up lamp and lamp consume more current then specific value so protection activates and turn off TV, usually TV turns On by itself again and green LED blinks, no picture and TV turns Off again and this cycle keeps going on.
I'm Sony TV tech and fixed many TVs with same problem. Replace Lamp XL-2200 under following part number..for KDF-E55A20
A1085447A LAMP BLOCK ASSY XL-2200U
Available in Sony Accessories Store for $200
Please buy Sony original lamp for TV safety and avoid aftermarket / cheaper lamps.
Let me know further query about TV, if any.
Thanks.
Posted on Jun 23, 2009
    President:
  • 1,383 Answers
This is becauee of circuit issue.
There should be blown thnig on Circuit of TV.
Check its fuse , Diode and register transisotr.
But if you are not technical person of tv then you need dto call TV repairer .
Also you can try another power supply becasue some times voltagew fluctuation and earthing problem create problems.
    Sergeant:
  • 326 Answers
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
My sony led tv model # kdl60ex700 blinks 6 times my sonny TV blink 6 times model # KDL-60EX700. What is wrong
I need more information like:
When it is turned on,
Turning off,
Connecting to something,
To close to the wall......Things like this to better you with your problem.
Aug 27, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
My KDF-E55A20 sony LCD projection t.v. when i turn it on the power light blinks red 6 times
Thats caused by missing DD6v from the GM board replaceing the GM board should solve the problem there were two versions used based on your serial number. You can get the correct GM for your application from www.tvrepairworld.com
Oct 18, 2012 | Sony KDF-E55A20 55-Inch LCD Rear...
Sony grand wega kdf-e55a20 will not turn on when trying to turn on green light switches to red blinking light (this is not the replace lamp light)
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL-2200.Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
KDF-E55A20 SONY DLP TV. This Tv won't come on and the LED blinks 6-times. Any suggestions?
6 times red light blink shows problem with power supply board (GM Board) that will be replaced.
Let me know if you want to replace GM Board by yourself to provide you part number info.
Thanks.
Jan 22, 2010 | Televison & Video
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
I have a sony 52" tv model kdf-e55a20 dont start up
Probably lamp. usually powersupply will give the first click but not the second to power up the lamp. there is no horizontal fix for that type of tv
Jun 02, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv is on after less tha a minute turn off
IF YOU HAVE ALREADY TRIED REPLACING THE LAMP YOU NEED TO CALL A SONY SERVICE CENTER THERE IS A CONFIDENTAIL SERVICE BULLITIN FOR THIS PROBLEM E31795896.
May 23, 2009 | Sony KDF-E55A20 55 in. LCD Television
No picture no sound
Thats great that TV is working fine. How about rating solution as 4 blue diamonds?
Thanks.
Mar 04, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Power button
Sorry, I have to say it. If the bulb (LED) is shot it would have to be zero flashes :-) It's my weird sense of humour. After that I hope you'll forgive me and someone can give you some real help.
May 27, 2006 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
