Question about Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV
1999 polaris slh 700 no spark
Ran when I bought them. changed the batteris now no spark
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
Polaris troubleshooting
Have you cleaned the carbs and fuel tank , checked the plugs and coil ht's and connections ?
Aug 04, 2014 | WSM 1999-2000 Polaris Slh 700 Cc Jet Ski...
1997 Polaris rmk 700 has no spark. Kill switch is in run position and key is on. Sled ran fine last year. I get a little tail light when I pull starter rope
try bypassing the kill switch and the ignition switch. Often the switches fail before the other components. the ignition can usually be bypasses by simply unplugging it from the harness. You may have to loop the wires to bypass the kill switch.
Jan 22, 2011 | Polaris New Genuine Polaris Snowmobile...
09 700 ranger wont idol
Could just need maintenance service (spark plug, air filter, oil change).
Idle could set to low, but if it was idling OK, the idle doesn't normally change.
Could be throttle position sensor (TPS), or fuel pump. Polaris Dealer can hook it up to the diagnostic port and see what's happening.
Hope this helps.
Sep 12, 2010 | Polaris ATV
I have a Polaris 700 ATV, need to replace spark plug wire
I think it just pulls out.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Apr 10, 2010 | Polaris ATV
No spark at plug on 99 polaris 250 trailblazer
i bought a 92 polaris trail blazer im very confused cus it has no battery and no battery leads going anywere and it has a back up pull start but its not geting any spark at all what should i do im not very good with quads?
Oct 07, 2009 | Polaris ATV
2003 sportsman 700. no spark at plug. off/ run switch is in run position. why no spark?
Have you been running the bike with a low battery? Have you changed the spark plug? Have you checked that a fuse isn't blown? Check these items if all is good, chances are that the pulse coil or pick-up coil is shot, could also be the stator. Have someone who knows how to check it for hons of resistance.
Aug 12, 2009 | Polaris ATV
Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV Logo
74 people viewed this question
Top Interactive Toy Concepts Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
