How much to REPLACE 2-4 BULGING CAPACITORS on Samsung ps50a456p2d
Telly wont turn on , red standby light just comes on for a second then goes off
  • 398 Answers
Replacing capacitors is relatively simple, The caps range from a few cents to a couple of dollars (I can not be more specific without knowing exactly which ones are effected) of course most repair shops will "mark-up" the cost of parts. If they charge much more then that they are overpricing the parts.
The labor rate is also highly variable, but I would not charge more then a hour to 1.5 hours of labor. Check with the repair shop in your area for a estimate.
Posted on May 12, 2014
  • 1039 Answers
SOURCE: 13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Posted on Apr 25, 2009
  • 41 Answers
SOURCE: wont turn on red light flashes
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
Posted on Mar 30, 2009
SOURCE: 37FD9954/17
hi, i have read somewhere that you need to replace both 100u / 25 caps aswell.
the info came from a user on here called PaleFace but i cannot find the original post now and i have the same problem with my tv.
Posted on Dec 31, 2008
  • 257 Answers
SOURCE: Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
Posted on Aug 13, 2009
SOURCE: red light flashing on samsung le40a stuck in standby mode
hi nick think it may be blown capacitors on your power input board?
Posted on Oct 16, 2009
Tv wont turn on red light stays on but green light goes off
The capacitors on the power supply need to be replaced. When you take apart the TV, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video on how to replace capacitors.
Oct 05, 2014 | Samsung LN60C630 60 in LCD TV
Samsung plasma TV wont turn on.
A capacitor can be bad without bulging. Is it a constant clicking or just one?
Apr 19, 2013 | Samsung 51"" Class 51.0"" Diag. Plasma 530...
Standby light flshes 7 times on tv sony KDL-46z4500
that is power supply issue try to check if there is bulged capacitors on power board then replace it.
Oct 28, 2012 | Televison & Video
My tv is on standby but wont turn on it the blue light goes off as if its going to switc on but comes back on after a few seconds
The problem of your tv is the power supply board. Try to remove the back cover of your tv and look around the power supply board if you can find this capacitors it has a electrolite gases leakages at the bottom of the capacitor and also if you see some bulge up on the top of the capacitor or not perfectly flat, replace this capacitor but remember the proper position of the capacitor because it has a polarity. Note unplug the unit before removing the back cover. Good day and best regards.
Aug 08, 2011 | Televison & Video
My toshiba 32kv500b wont turn on, the standby light extinguishes after 2 seconds when the on off switch is turned on, there are noises coming from the tv when i press the manual buttons. Any ideas
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where,if otherwise the power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem....
May 15, 2011 | Televison & Video
I have a Sony Bravia KDL-40W5500 LCD TV (11months old) that does not show a picture when turning on from standby. Sometimes it only gives sound for a shot while then automatically reverts to standby. the...
probably there is a problem on the power supply section of your tv the cause of it is a deffective bulging capacitors.replace all the bulging capacitors from the power supply.
Oct 16, 2010 | Sony Televison & Video
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
Idlcd32tv27hd comes on for 1 second then goes to standby
REPLACE 2-4 BULGING CAPACITORS IN THE POWER SUPPLY BOARD, PLEASE LET ME KNOW IF FIXED. THANKS
Mar 15, 2009 | Televison & Video
T.v. won't turn on
Open the back of the TV,and look at the can shaped items called capacitors on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.Most of the time the big black capacitor on the power board goes bad,and bottom bulges out,but sometimes it is the other capacitors as well.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Nov 17, 2008 | TruTech PLV16320 Television
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
