Question about Casio Parts Cash Register PC Desktop
Casio Te-4000F Error E050
I got a used TE-4000F. Re-initialized and reprogrammed the device and everything worked fine so far. Now I tried to use the check tracking system but I cannot create a check. I immediately get an error E050 meaning check tracking detail memory is full. But there is no check existing. What could be the problem? Is there a dedicated RAM for this purpose which is maybe broken?
  • Casio Master
  • 1,668 Answers
You should first check that you entered the correct digit for check tracking and not scanning file when you typed in the init code. Check your init code by performing a flag clear. If that is ok, Print out the memory allocation (program 5) and make sure you have allocated memory for check tracking.
Posted on May 12, 2014
Testimonial: "You saved my day! Memory wasn't allocated means in fact I initialized with initialization pattern "For scanning" instead of "For check tracking". Resulting in need to reprogram the whole register, but anyway it works now. Many thanks!!!!"
  • Electroboy
    Electroboy May 14, 2014
    Yep. Done it myself. You have to give yourself a kick, hehe. The machine uses a large piece of memory for those two jobs so it can't do both. It is what you'd call hospitality or retail setting
flexion1
  • 737 Answers
SOURCE: error code 105 for casio te-2200
Hi.
We can check the memory allocation.
Turn key to program mode.
5 SUBTOTAL SUBTOTAL (must press subtotal twice).
This will print memory allocation.
Look down the printout and tell me what figures are listed under file numbers 16 and 40.
Mark
Posted on Jan 05, 2009
flexion1
  • 737 Answers
SOURCE: How to change the business address on casio te 2000
To change the first line of the receipt, Turn key to program mode 2 SUBTOTAL 132 SUBTOTAL Now type the new message using the characters on the front of the buttons. 00 (double zero button) CASH SUBTOTAL
To change the other lines of the receipt, substitute 232 for line 2, 332 for line 3, or 432 for line 4 in place of the 132.
If anyone needs a Casio TE-2000 manual, go here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Posted on Jun 05, 2010
Electroboy
  • 1668 Answers
SOURCE: error code E050 detail memory full register will
Which brand and model?
Posted on Sep 05, 2010
Electroboy
  • 1668 Answers
SOURCE: I have just bought a
Which data did you need to clear? It might be easier to edit the program so you don't have so much work to do.
If anyone needs a Casio TE-M80 operation / programming manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-M80_users_and_programming_manual.html
Posted on Oct 26, 2010
Electroboy
  • 1668 Answers
SOURCE: i have a casio te
Ok. See if you can get rid of the buffer full error for a start. try pressing clear (C) then press Subtotal. You should see an amount on the display. Now press the ERR CORR/ CANCEL button. This should stop the sale that you are stuck in.
Turn the key to Program mode. If it gives error as you turn the key, then you haven't finshed in REG, turn back to REG and try to end the sale first.
If you see P01 on the display, it has worked and then do this:
1 SUBTOTAL 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL.
Now turn back to REG and try it.
If it still didn't work, let me know what happened, and I'll show you another method
If anyone needs a Casio TE-4000F manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Posted on Jan 31, 2011
Casio te 2200
Hi Good Day!
Before you reprogrammed it, check everything first,
if there is a reset setting, try to use it before you reprogramming it.
Mar 26, 2014 | Casio Parts Cash Register PC Desktop
Cassio TE-4500F
You have put too many items into a guest check (tab). Finalise (pay off) the check to free up the memory.
If anyone needs a Casio TE-4500 or TE-4000F programming manual, one of the users has it here:
Dec 04, 2013 | Casio Parts Cash Register PC Desktop
I'm tryng to change a drink name on a casio te-4000f and put the wrong letter in the drinks name, how do i delete the wrong character?
The decimal point deletes a character. If you have finished the programming, just program the name again and it will correct it.If anyone needs the Casio TE-4000F programming manual, try here:
Dec 04, 2012 | Computers & Internet
TE-4000F shows error code E053 and power failure issue
C-tech said he is helping with this problem. He'll sort you out
Feb 29, 2012 | Casio Parts Cash Register PC Desktop
How do i take off a change amount that seems to have beeen programmed into my casio te4000f everytime i ring up a sale...
Try this:
Turn key to program 0 CASH SUBTOTAL Turn key back to REG
If anyone needs more information, the Casio TE-3000s, TE-4000F and TE-4500F manuals are here: http://the-checkout-tech.com/manuals/cashregisters/Casio5.php
Mar 20, 2011 | Casio Parts Cash Register PC Desktop
I have a casio te 4000f and it will not let anyone ring in when sub total pressed it is counting down in 1p also saying buffer full??? help
Jan 29, 2011 | Casio Parts Cash Register PC Desktop
Hi, I have a Casio TE-4500F and am having problems configuring the clerk interrupt function. If I Iog into the register using one clerk number say 1 - CLK#, as soon as I have pressed a PLU key to start a...
Are you new balancing before you try to log the second clerk on? Make sure you don't have the check tracking selected. You can use interrupt or tables, but not both.
If anyone is looking for a Casio TE-3000, 4000F, or 4500F manual, c-tech can help
TE-3000S operation manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_users_manual.html
TE-4000F, 4500F operation manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-4000F_and_TE-4500F_users_manual.html
TE-3000S, 4000F, 4500F programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Oct 19, 2010 | Casio Parts Cash Register PC Desktop
We have bought a cafe and the second hand Casio TE 4000f electronic cash register but it appears to have frozen so we cant enter any date. The display says PGMX and the amount 0.00 is displayed. Even...
PGMX means the machine is trying to print a current program report. It may have been interrupted. Try this procedure to jump it back out:
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Turn key back to REG mode (you may need to sign on if asked)
If anyone needs a manual for a Casio TE-4000F cash register, http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Sep 12, 2010 | Casio Parts Cash Register PC Desktop
How do you program HST on my TE4500?
Which tax number has been set for HST? you have to set the rate on the correct tax number.
If anyone needs / looking for a Casio TE-3000, TE-4000F, TE-4500 manual, c-tech collective have them here:
Aug 31, 2010 | Casio Parts Cash Register PC Desktop
Hi I have a Casio TE-4500F, everything works but the cash crawer does not open. I have been led to believe this may be a fuse on the main board. Is this a job I can do myself or does it need an engineer? ...
The only time it will blow the fuse is if someone has shorted out the cash drawer wiring. Check the wiring to the drawer first, and insulate any bare wires. Then you can replace the fuse. It is a solder in type on the main pcboard. Sometimes the half watt resistor in series will be cooked as well. --------------------------------------------------------------------------------------------------
Anyone looking for a Casio TE-4000F / TE-4500F manual? http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
May 18, 2010 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
435 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
