Question about Fishing
How do i fix Nautilus 5/6 wt. fly fishing reel. Re-assemble spool release side.
I want to put red cap on and spring , lost one screw will get another.
  • 549 Answers
There are some videos on youtube.com that may help. Nautilus website does not show how to assemble this reel. Nautilus FW hub assy MOV
Posted on May 12, 2014
Where is the bail spring located
There is a company that has schematics for many reels.
Google
make model schematic
In fact, I think I found it. Mike repairs and supplies parts.
The bail spring is either external as part of the bail arm mounting, or inside after removing the spool.
Fishing Reel Schematics
May 25, 2016 | Fishing
How do I release the spring tension on this reel? How does one separate the top from the encased spring load area?
If this is fishing equipment, you have posted in wrong section. If this is automotive item, sorry, I am unfamiliar with it.
Aug 11, 2015 | Cars & Trucks
How can I get my reel to cast smoothly?
Hey Ken, Neil here from Dark Side Reelz. it boils down to over oiled bearings, or bearings that require cleaning, your spool shaft only rides on 2 or max of 3 points, (depending on reel make) each of those points contains a bearing the spool shaft seats in those bearings any build up will greatly reduce casting distance. I specialize in reel cleanings, rebuilds and restorations as well as custom work like upgrades and super tuning. If you would like to read some really good info on what you can do read this article I wrote http://ezangler.com/tackle-box/gear-tips/the-reel-truth/ here is the link to my webiste as well www.darksidereelz.com
Jul 05, 2014 | Generic Ardent C400 Fishouflage Bass...
How do you change the retrieve to left or right hand on a orvis encounter fly reel ?
Drag factory installed for left-hand wind. To change your real to right-hand wind, remove spool, pull the keyed bush and clicker plate assembly off the spindle. Flip the clutch bearing (silver) and reassemble.
May 21, 2014 | Orvis Encounter Large Arbor Fly Reels &...
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How do you assemble the inner section of the reel and what is the spring for and where does it fit.Where does the piece with the grey one end and white screw end fit? Instructions with pack are not clear...
the spring goes under the spool(where the string is wound), the outer housing is where the grey piece and screw are used, as it secures the head to the shaft. you will need to put the outer housing one,then the grey piece,the screw,the spring,spool and then cap. Hope this helped Tim
Jun 11, 2011 | Garden
How do you cast the reel so the spool dosent continue to unwind after the cast
On the side of the reel there is a knob that you adjust for the spooling.As a rule of thumb you adjust it so when you have a lure on,click the release button and let it spool out,it will only drop about 4 feet.Now! tighten it a fraction.Start casting and it will not go very far.Just before the lure hits the water,you put your thumb on the spool.Hard at first and then less as you get used to it.You can then adjust the spooling knob to go a bit further every time.You use your thumb on the spool to adjust the last 10 feet of line.Use a lure with no hooks on it to practise.It's called a plug.Hope this helps and you reel in the big one's
Sep 21, 2010 | Penn 320GT2 Graphite Levelwind...
Left hand retrieve
Unscrew handle put on other side .
May 12, 2010 | Scientific Anglers Scientific Angler...
Fishing Logo
176 people viewed this question
Top Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Fishing Expert? Answer questions, earn points and help others
