Question about Mercedes-Benz Vehicle Parts & Accessories
How can I disengage the engine immobiliser?
Engine immobiliser won't switch off?
  • Geoff Sowden
    Geoff Sowden May 14, 2014
    The engine cranks but but makes no attempt to fire.
  • Geoff Sowden
    Does the immobiliser kill the spark or the funk pump?
  • 5 Answers
What year is your car? The immobiliser communicates with your keyfob which has a transponder in it. If you recently gotten new keys, you would have had to swap out the old transponder or have your new one reprogrammed.
Posted on May 17, 2014
How do I disengage the engine immobiliser on my 300SL R129
please say what disengage means.
1: defeat?
2: make it work right?
3: stop the lamp from glowing and being unhappy (1996 MB)
Sig: I must ask questions first, I'm blind, and my tools can't reach, dig?
May 12, 2014 | 1996 Mercedes-Benz E-Class
Speedfight 2 won`t start up now
Check the wireing; any loose ends etc.
Check the fuellines.
Check if any cracks in the blocks etc.
Mar 08, 2014 | Peugeot Motorcycles
Turns over but won t start
make sure that a signal is generated from the crank position sensor when cranking the engine if not sensor is faulty . Otherwise check for spark at plug leads check for fuel pressure at the rail and make sure immobiliser is disengaging
Jan 21, 2014 | Suzuki XL7 Cars & Trucks
1998 terrano immobiliser fault wont start
hi, i have nissan terrano wen i switched on engine light flash and start engine its start then go of.nissan terrano patrol engine
Sep 06, 2012 | Nissan Sentra Cars & Trucks
Won't start
Switch on head lights or cabin light. If they doesn't come on or is weak, the battery is flat. Ensure that you switch off the lights.
With ignition switched on, assuming the lights on the instrument panel cames on and your immobiliser is deactivated, turn ignition to start. You should hear the solenoid at the starter making a click sound. If not, the battery is flat or the starter solenoid is faulty. If it does make a click sound, the battery could be too low to turn the starter or the starter is faulty. Assuming the immobiliser is working correctly, and the starter tries to turn the engine but it doesn't want to turn, the gasket could be blown and the cylinder filled with water, or the engine could be seized.
Hope it is not the last case. MarioCpt
Mar 06, 2012 | 1999 Toyota Corolla
I have a craftsman mower with the B&S 21hp Intek OHV motor, it starts fine but when you go to engage the blade or go forward or backward or release the parking brake it will die unless you disengage...
Check the switch on the seat, of all places. There's a safety switch on the seat that will kill the engine if it's not engaged when do anything other than start and run the engine.
If the switch checks out, get back with me.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Landcruiser VX 1996 will not start since I changed the battery
dealer only to re programme key into car it can only be done with vehicle, not away from it .Sorry for no easy fix unless you want to disengage the factory immobiliser,which if its a diesel is a fairly simple procedure but not for a petrol engine
Nov 27, 2008 | 1996 Toyota Land Cruiser
Engine immobiliser fault light on after battery flat
There might be an immobiliser fault or a problem with the key transponder but try the following before you call the dealer or local auto locksmith.
Disconnect the battery and leave overnight. Next morning open the car, put the ignition key in and switch on the ignition - then connect the battery.
Sep 17, 2017 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
98 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
