Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Robinair 34788 clearing problems - Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
mhkamran
  • 180 Answers
SOURCE: Robinair 34788 not pulling a vacuum
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robin air 34788 machine having same problem.You can try as follows 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Posted on Jun 07, 2009
mhkamran
  • 180 Answers
SOURCE: ROBINAIR 34788 NO MANUAL REFILL
You may did not open the tank valve before you press fill key! please try as bellow:
Connect tank fill adapter to source tank & open tank valve then make the tank up side down,now press tank fill key. screen will change to checking source tank for 30/60 sec. then start filling.
If you try as above direction & still the problem exist,it may need to replace or rebuild tank fill solenoid.
Posted on Jul 14, 2010
mhkamran
  • 180 Answers
SOURCE: robinair cooltech 34788 scale error reset
You may overfill the ISV tank. #1 Open front cover & close LIQUID valve on the ISV. #2 Disconnect LIQUID hose from tank,then open tank liquid valve (which you close earlier) to reduce some refrigerant manually from the ISV tank. #3 after reduce refrigerant from tank, re-connect everything & switch on the machine. #4 If you still have the same problem then you have to re-calibrate the scal. I hope this will help you
Posted on Nov 05, 2010
mhkamran
  • 180 Answers
SOURCE: Robinair cooltech 34788 displaced high
You Have to replace the PCB Relay Board
Posted on May 17, 2011
mhkamran
  • 180 Answers
SOURCE: i have a robinair 34788 and when i tunr it on it
This is a common problem of Model: 34788, 34788-I, 34988, AC34788, GE48800 etc.
You need to replace air purge solenoid (Air purge solenoid located on top of the ISV tank, if you open front panel cover then you can see it on top of the tank).
After doing above stapes and your problem still exist then you have to replace PCB relay board.
Hope this will solve your problem, if so please vote for it for farther help! Good luck
Robinair 34788 keeps overcharging the isv how do i fix this issue or how do i find out whats wrong
Robinair 34788 Set Up Operation Part #1 - YouTube
? 6:05
www.youtube.com/watch?v=XW8o5tahLpE
Aug 30, 2013 - Uploaded by OTC TOOLS This video takes the viewer through the entire Set Up and Operation of the 34788. The Cool-Tech 34788 ...
Aug 26, 2015 | Robinair Measuring Tools & Sensors
We have a robinair 34788 and it wont recover
Does it flash any codes on the screen when you attempt to recover? You'll want to check the inline filter as well as the condition of the pump oil.
Aug 03, 2015 | Robinair 34788
How to replace tank fill solenoid on robinair 34788
No, you cant remove tank fill solenoid until close low (Blue) and high (Red) side valve on ISV tank (Internal storage vessel). see attached picture to identify Tank fill solenoid. 39b3bb9f-14fe-4040-a186-3a3a23d2848e.jpg
Jun 18, 2014 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 34788 and when i tunr it on it shows a massage "hi pressure "
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
HELLO I HAVE A ROBINAIR 34788, MY UNIT WILL NOT CLEAR THE LINES. I TRIED SHUTTING OFF AND ON , BUT LINES ARE STILL HOLDING PRESSURE. I ALSO CANT RECOVER BECAUSE IT WILL NOT GET PAST CLEARING. THANK YOU
sounds like you need to check the grommet between the motor and the pump. If this grommet connector breaks, the motor will come on but the pump will not work. Turn the unit upside down and look where the motor connects to the pump. Be aware if you can lose your oil while turning upside down unless you cap the port and exhaust. If this is it, go straight to the Robinair web site and you can order one for around $25.
May 11, 2011 | Robinair CoolTech 6 CFM Two Stage Vacuum...
Jul 14, 2010 | Robinair Cool Tech 34700Z Recovery,...
High presure rest on robinair 34788
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robinair 34788 machine having same problem.You can try the following 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Aug 09, 2009 | Robinair Cool Tech 34700Z Recovery,...
Jun 06, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
64 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
