Question about Cannon Office Equipment & Supplies
Cannon m560paper not feeding correctly - Cannon Office Equipment & Supplies
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Always paper jam error on my cannon 3530
Check for a paper fragment at either end inside the printer chamber or underneath the paper feed roller cover plates. Anything that holds a paper feed sensor arm open will give you paper feed errors, and they can be remarkably small.
May 14, 2015 | Cannon Office Equipment & Supplies
Our Cannon MP210 feeds more than one sheet at once
Make sure you fan the paper properly and it may need a new separation pad, also make sure the side guides are tight on the paper and the paper can't move around.
Oct 14, 2014 | Cannon Office Equipment & Supplies
How to fix paper alignment
There is not enough information to really answer the question. However, if the paper is not "feeding" check for jams of other paper inside the printer.
The "FEEDER" part where you put the paper in usually has "SLIDEABLE" guides to keep the paper feeding correctly
May 03, 2014 | Canon PIXMA Office Equipment & Supplies
Paper Feed problems for Cannon MP600
Mechanism Problem replace the mechanism with new one.
Jan 01, 2013 | Canon PIXMA MP600 all-In-One InkJet...
I am not able to feed several documents into my Cannon MF6500 printer to be scanned. I can only scan one document at a time. How do I correct this so I can feed documents in to be scanned
Do you have problem with multiple copies or just wit puling scans?
Try to say that the original is feed from adf, clean rollers if you have trouble with copie too.
May 18, 2010 | Office Equipment & Supplies
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannon MP460 will feed paper through printer but not print
Check your printer sharing in the system preferences... make sure it's on.. then when you get the print window, look for your printer under shared printers... try it that way... worked for me on my wifi network here.
Mar 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Cannon printer feed paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Canon PIXMA iP1600 Printer
15 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
