Question about Hayward Offline Brominator
What would cause my Brominator to leak from underneath.
The pipe connection joints are fine, but there appears to be a leak underneath.
    Scholar:
    New Friend:
  • 66 Answers
If it is an offline model you should be able to turn it upside down while pump is running and see the leak.
Posted on May 14, 2014
My brominator is always leaking water from the top even though it is securely fastened. I also never know how many bromine pucks I am supposed to put in since I do not see an demarkation on the inside...
If I had these problems I would call Hayward technical support at 908-355-7995 and they would help with precise answers to your questions.
Please let me know how this works. Thank you.
Sep 02, 2011 | Hayward Offline Brominator
Water is leaking from the pipe on the top of the tank (Reliance 606 electric) where the hot water comes out and goes into the house. Likely causes?
If tank is rusted out, then that is caused by depleted anode rod, or tank that is not electrically grounded on hot side pipe.
If pipe nipple is rusted out, then that can be caused by improper connection between copper and galvanized pipes, and caused by non-grounded hot water pipes.
If tank is leaking, replace it.
If nipple is leaking, remove with pipe wrench, apply teflon tape or joint compound on threads, and install new nipple. Replace anode rod if possible. Correct copper-galvanized connections. Add ground wire between hot and cold pipes.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Aug 25, 2011 | RELIANCE ELECTRIC WATER HEATER
Water coming from the back of the shower
most likelt your home has copper water pipes. If the shower head's pipe has any movement the sweated solder joint is most likely cracked causing the leak inside the wall. If it is mounted securelt one of the sweated connections has a faulty solder joint that needs to be resoldered
Aug 19, 2011 | Home
I unclogged the GD by removing the pipes underneath and replaced them tightly. GD seems to be working fine now, but water is slowly leaking from underneath the GD! It appears to be leaking from the...
The leak comes from above where water comes out.
Turn off power before touching wet electrical appliance.
Put stopper in disposal.
Fill sink with water.
Check if water is getting through the putty seal at sink connection.
Next, check if water leaks only when dishwasher runs. Dishwasher drains into garbage disposal.
Last, check tailpiece where it attaches to side of garbage disposal. The tailpiece is usually sealed with a rubber washer. When washer is old, it gets deformed, and then it doesn't seal perfectly when put back.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
It is gooey and sticky.
Brush it all over the washer, use plenty, then assemble pipes.
The rectorseal assures that joint will not leak.
Oct 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a problem with my new drain leaking underneath the ball joint. (not out of the ball joint ) .water keeps beading out where the crome pipe reduces into the rest of the rougher looking metal. I cant ...
Get it clean and dry... then wipe a good quality silicone caulk around the jiont and let it dry completely...this will seal that joint for you...
heatman101
Aug 23, 2010 | Moen 103459 Drain Pop-UP Plug
Hoptpoint WD64 appears to be leaking. Puddle appears an hour or two after cycle completes as expected. Any ideas why / any maintenance I can undertake to resolve?
If leak is occuring after wash is finished I would suspect a leaking outlet pipe joint around the pump as water will still be present in that area. If it is a leaking joint it may just need tightening, but to help it, only if you wish to, disassemble the joint and apply some instant gasket, type used in automotive assembly, and reassemble the joint and tighten. DON'T USE SILICONE SEALER as you may want to get the joint apart at a future date.
Feb 14, 2010 | Hotpoint Aquarius WD640 Front Load...
Oxygen Sensor Mitsubishi Verada 2001 Wagon
the oxygen sensor is mounted on the top of the exhaust directly behind the 2nd exhaust inlet, basicaqlly where the 2 pipes meet into one, is screwed in from the top of the pipe. possable that the flexable joints of this pipe may have been damaged and exhaust can leak form these joints
Jun 23, 2009 | 2001 Mitsubishi Montero
Water leaking from underneath pipe connector to the dishwasher
Check the following:
* Loose or mis-positioned hose clamp at the drain spur connection
* Rotted or brittle hose
* Split hose
* Cracked joint at the drain spur connection or split drain spur fitting
Apr 27, 2009 | General Electric Dishwasher Timer
My Daewoo DSB 091L unit has started to drip condensate from the casing joint underneath the front drainage tray. I have cleaned the blocked drain pipe and proved the water drains away. The condensate drip...
Make sure that the flexible pipe is securely connected to the drainpan, it can come adrift and cause leaking. The way to check this is to make sure everything is dried out completely. Then open the front grill and carefully pour water so that it goes only into the drip pan. Pour slowly so that you do not overflow the pan. If water is coming out on the outside and you have no leaks on the inside, then you can rule out the perished or disconnected drainpipe theory. In this case your unit may be short of refrigerant causing excessive run time and a freeze up of the evaporator.
Mar 24, 2009 | Heating & Cooling
Hayward Offline Brominator Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
