Go to searspartsdirect.com type in your model no. It will be something like 700.000111 be sure and include . Then look at diagrams and try finding brake system.
First I would look for the receipt and owners manual, see if it is under warranty. If not I would get the *** end of it up on jacks, remove rear wheels and any cosmetic panels, and take a look at the point where the lever pivots or hinges. Most likely there is a mechanical linkage which as gone afoul. With all the vibration on a mower often times a pin, key, or other keeper comes loose.
I have to assume you are trying to install a newer blower made in the last five years to the GT 5000.
Two ways to get the manual. But you need the model number off the snow blower attachment itself. The blower is made by Agri-Fab.
First way. managemylife.com. Click on the manuals tab, put in your model number and get your free manual.
Second, if you can't find it on managemylife.com. http://www.agri-fab.com/manuals.aspx. Push the "click here" in the middle of the page to go to the manuals section. If you are having problems call the 800 number on the top of the screen.
The most likely suspect would be a bad seat switch or the plug to it has come off.To test it if the plug is still on the seat switch just stick a small piece of wire with then ends bared into each connector to "jump" the seat switch then if you can now let off the brake without it quiting the you know that you need to get one.
If the fuel filter is not clogged and stopping fuel from going to the carburetor then leave it installed until it is full of particulates and restricting fuel flow.
