Question about Dryers
I have a Whirlpool Gold senseon Model number GeX9868Jq1 I can feel the heat inside to Dromm but when I push start it just clicks It's a electric dryer
  • 148 Answers
Unfortunately, it sounds like the motor, since you aren't hearing it run. Motor turns the drum by way of a belt.If motor is running, but drum not turning, it would be the belt... I would also say door switch, but then the heating element wouldnt be heating up. Slight chance it could be the control, but I doubt it. DW
Posted on May 13, 2014
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool model ler4634bq1 electric
Check for lint buildup and then see if your duct fuse is bad df844d7.jpgec250a4.jpg74541d9.jpg
Posted on Mar 22, 2010
SOURCE: Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Posted on Jun 09, 2010
Daniel S
  • 4323 Answers
SOURCE: Whirlpool Gold Ultimate Care II,
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 13, 2011
heatman101
  • 43501 Answers
SOURCE: I have a Whirlpool Gold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Posted on Sep 19, 2011
Why won't my Whirlpool Senseon Dryer start? The control panel will not respond. No buttoms will light up or beep. The dryer has power and the door latch works properly and the light comes on inside
Always disconnect power before attempting any service. Most electric dryers require 240 volts to operate properly.
You may have only 120 volts to supply the dryer which will give you your symptoms. Click dryer circuit breaker off then back on to reset 240 volt system.Still no heat/run
This link will aid you in tear down / diagnostics/parts
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Nov 21, 2017 | Whirlpool Dryers
Whirlpool Senseon dryer control panel won't work
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
Oct 14, 2012 | Whirlpool LER4634J Electric Dryer
Whirlpool Gold Electric convection oven does not heat up.
Check for a broken wire or even broken element on top and bottom of unit. To do this, the unit must be unplugged or otherwise removed from power completely, then remove the screws that hold each heating element in place and gently pull out and inspect the wire connections. You should have just enough slack to check them. There should also be just enough slack to strip the wire clean to make the new connection to the heating element.
If the repair has been done before, you may need to fish a new lingth of high temp wire into the location.
Jul 13, 2012 | Whirlpool Ovens
Model gew9868KQ2 wont start E7 code
How do you remove the Toe panel off of the Senseon Electric Dryer?
Oct 18, 2011 | Whirlpool GEX9868J Electric Dryer
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
heatman101';
Sep 19, 2011 | Whirlpool LER4634J Electric Dryer
I have a whirlpool gold electric range,accubake model gy397lxus.oven not heating and range top not heating,digital control blank unless i rotate a heat selector for range top to on,the light indicators for...
I have look up your unit, I found the thermostat located inside the back panel the would only take out the function to your elements in your oven.
High limit thermostat
This link shows its location and price of the part. Now for you display issue, before continuing, push and hold the clock button on the panel until you hear a beep, if the unit is set to Sabbath mode this will clear that. If not I will continue, by the way missing a version number to model number, like a number (0 or 02). Have you have a power outage recently? I am not locating any line fuses the would take the display out. If the clock doesn't reset then I would think about checking warranty or can your dealer to inquire on your warranty.
Control Unit
Good Luck and I hope this helps.
Aug 17, 2011 | Whirlpool GY397LXUS Stainless Steel...
Where can i find a model number. It says Senseon on the front door
Usually the model and serial number are on a sticker inside the dryer door.
Feb 10, 2010 | Whirlpool Dryers
Whirlpool Senseon dryer GEW9868kq
The element is controlled by thermostats mounted inside the back of the dryer on the air exit box. There is also a contact on the motor that makes when the motor is running. Any of these could cause the problem. Try a different heat cycle, this may help narrow it down.
Jul 03, 2009 | Whirlpool LER4634J Electric Dryer
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
