Question about FoodSaver V3250 Vacuum Sealer Kit
V3250 sealer , no operation
No lights, no power, and operation
  • 45 Answers
Check the power cable and the swich.
Posted on Jun 25, 2014
Where can I purchase Polyscience 300 Series after checking the price?
Vacuum sealers are a great way to get more out of the food you buy. With proper storage, they can significantly extend the lifespan of your food, prevent spoilage, and minimize waste. They're a powerful money-saving tool that benefits families, homeowners, and food lovers. POLY SCIENCE 300 SERIES is the best sealer and comes with features like :
  • Versatile vacuum sealer that works with a large variety of different foods
  • Built-in marinating cycle extends the abilities of this machine
  • Stainless steel construction and many more. To get the price detail click here.
Apr 20, 2017 | Vacuums
How to Choose a Vacuum Packaging Machine?
When purchasing vacuum packaging machine, due to there are too much alternative models, people always become confused that how to choose a suitable vacuum packing equipment? Following analysis is conductive to your choice.
1.To determine the nature of products.
Different vacuum packaging machines are suitable for different products, some products with special properties, such as fluid, powder, granular and lump objects, etc., should not only satisfy the vacuum packaging function, but also asked to achieve better effects of vacuum packaging.
2. To select the appropriate vacuum packaging machine models.
Thinking about the function, vacuum packaging machine has many types, including ordinary ones, rolling ones, continuous stretch film ones and small vacuum packaging machine, etc, according to different production, people can select vacuum packaging equipment that fit themselves.
Different functions: Automatic stretch film packaging machine, single or double chamber vacuum packaging machine, automatic vacuum packaging machine, skin packaging machine, cassette vacuum packaging machine, rolling vacuum packaging machine, air switch installed packaging machine.
Different materials: all stainless steel, semi-stainless steel, ordinary steel, plastic spraying.
Different vacuum pumps: domestic special pump, imported vacuum pump, special vacuum pump. Imported pumps are more expensive, domestic pumps are relatively cheap, customers can choose them according to the practical situation.
3. Whether the power supply of workshop is suitable for vacuum packaging machine.
Some vacuum packaging machines apply to 380V power and some are suitable for the 220V power. If the power is too far away from the vacuum packaging machine, longer wires is required, and this situation may cause inadequate voltage, affecting production. Therefore, people should buy vacuum packaging machine according to the power of their factory.
4. Evaluate quality and after-sale service, etc. of vacuum packaging machine and choose cost effective vacuum packing factory, since this will reduce a lot of trouble for use.
5. Before purchasing a vacuum packaging machine, purchaser should consult with manufacturer on parts supply problems, to avoid delay in production caused by the malfunction of vacuum packaging equipment.
Dec 21, 2016 | Vacuums
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
Stuck closed, how to open?
press release on top cover , I had someone use mine 1ce and they pressed "seal" with no bag in machine it did exactly that it stuck closed, tight too !! one touch of release button on top cover and it popped open
Jan 15, 2016 | FoodSaver V3250 Vacuum Sealer Kit
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
The arm won't close on my v3250. The door only goes down part way?
I experienced the same problem yesterday. I somehow stumbled across the fix. I had the unit unplugged and used my thumbs to forcefully pull down the door (didn't use the handle). Once I discovered I could force it down with my thumbs, I plugged it back in while holding the door down and it seemed to reset itself and now works perfectly!
May 29, 2014 | FoodSaver V3250 Sealing Machine
Foodsaver v3820 does not vacuum
the pump is broken. would you like to repair this? if so let me know so i can give you steps---- assuming you have tried the obvious like ---another power source- toggling the power switch- looking for obstructions. let me know good luck
Mar 30, 2013 | FoodSaver V3820 Vacuum Food Sealer...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
How do I work a Salton vacuum bag sealer (Model BS-20)? I can not figure out how to get the air out of the bag.
This style of vacuum sealer has to use a special bag with a " dimpled " surface to let the air escape through the pinch jaws of the vacuum sealer.
The folowing web site has bags and rolls that can be cut ro make any size of bag you require. You can buy on line direct from the manufacturer as well as purchase more industrial vacuum packers
http://www.foodmc.co.uk/Category/113-textured-bags-for-external-bag-machines.aspx
Jun 14, 2009 | Vacuums
FoodSaver V3250 Vacuum Sealer Kit Logo
259 people viewed this question
Top FoodSaver Vacuums Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
ray gallant
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
