Question about Hoover Washing Machines
Dyn8163d8p Error code e05 and door won't open
    Habit-Forming:
  • 111 Answers
Has the programme finished but the door remains locked? Turn the machine to OFF to reset the machine and this will allow the door to open.
Then look at this > Has the programme finished? Is the END light illuminated? If not the programme is not complete. Has the door locked light gone out? If not wait a further couple of minutes and the light will go out and you will be able to open the door.
If nothing happens and door still locked, and you live in the UK you need to ring this number > Phone 08444 995 599 to book your repair
E05 is a fault on the temperature sensing circuit. You need to check the wiring to the temperature sensor at the bottom rear of the tub. (circular item near the element). Unplug it, check the terminals and the wiring, check the connector on the sensor. If all ok, take the sensor out, clean it and refit it. Try the machine again. If the fault persists and the wiring and connections are good, you'll need to try a new sensor. Check it out, see how it goes and get back to me if you need more help Hope this helps
Posted on May 12, 2014
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
Candy error code e05
The error code E05 means the temperature sensor has gone bad.
Aug 24, 2014 | Candy Washing Machines
Error code e61
Identification
  • GE dryers use three-character codes that display on LCD screens. Every code starts with "E" and is followed by a two-digit number.
Power Failure
  • When your home loses power, the "E01" error flashes on the screen. Reset the dryer memory by unplugging the device, waiting 30 seconds and plugging it back in. The error code will disappear.
Thermistor Errors
  • Errors "E02," "E03," "E04" and "E05" are thermistor errors. The thermistor, when operating properly, reads the temperature of the dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
  • When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Control Board Errors The control board sends signals from the controls to the dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE service or install a new control board for the dryer
Jan 15, 2013 | Electrolux Dryers
E05 code on breville oven
An 'E05' error message indicates that there is a non-resettable issue with the appliance. Please contact our Consumer Call Center at 1-866-BREVILLE (1-866-273-8455) for further assistance with your oven.
Dec 05, 2012 | Ovens
Lazy z spa error e05
You can find almost every error code known out there for hot tubs at the following link: Error Codes
Click on that link and then scroll down through them.
Rod
US Parts Center
Aug 26, 2012 | Jacuzzi Pool & Spa
What is Error Code E05 Canon MP258? and Error Code E03 Canon MP258?
Hello and Welcome to FixYa!
E05 Kindly see this link, (In Parts) E03 Kindly see this link.
Concerned, Nooh
Aug 12, 2011 | Computers & Internet
What does error code E05-11 mean?
there is a communication error on the device most propably caused by a problem with the large capacity tray feed unit loom. there is a techinical update for this problem and you would need a technician to attend.
May 15, 2010 | Panasonic Workio DP-4530 Copier
Ir5000 error code e000005-000. how do I clear it?
after fitting new cleaning web *28* takes you into service mode then follow the steps below to clear COPIER>COUNTER>MISC>FIX-WEB and COPIER> COUNTER>DRBL-1>FX-WEB.
Oct 11, 2009 | Canon imageRUNNER 5000 Copier
Washing Machines Logo
106 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
