Air conditioner icing over - Heating & Cooling
    New Friend:
    Problem Solver:
  • 7 Answers
Icing is almost always caused by one or both of two situations. Either low airflow due to clogged filter or evaporator and/or or low on refrigerant. If the filter and the evaporator (the radiator looking coil right inside the case) look clean, then the unit probably has a leak and has lost refrigerant.
Posted on May 16, 2014
Does this air conditioner need water
Air conditioners don't need water. if it is runnibng properly and blowing cold air it will produce water on the condensing coil. Look at the coil. If you see a lot of ice, turn the unit off and wait until the ice melts. If the ice returns it is probably low on freon. This must be taken care of by a licensed air conditioning tecnician.
Nov 17, 2012 | LG BG8000ER Air Conditioner
On my zoneline when you have the a/c on there is a ice build up going across the front of the unit just behind the filder you have to turn off the unit an let the ice melt off
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 30, 2011 | GE Zoneline AZ25E12D3B Air Conditioner
My air conditioner line is freezing and no air is coming out of the vents
Shut it down for a few hours and let it De-ice the evap coil is iced up/ check your filters and change them.. Oh to speed things up a bit. Just shut the cooling off and leave the fan on that will speed it up. You should see ice or condensate on the line. But set your stat to 74 and close doors to rooms not in use..
Jul 14, 2011 | Carrier 38CKC042 Air Conditioner
I need help my unit keeps frezzin up it always get ice on it i have to turn it off for a while to let it defrost thick sheet of ice y is this happening and how can i fix this
Either the filter is plugged up and the air flow is reduced or the unit is low on freon and has a leak...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 14, 2010 | Samsung AW0803B Air Conditioner
Air condition won't cool
mcdevito75 here YES IT DOES, I'm no expert but that ice is the problem, remove the cover and filter and let the ice melt, DO NOT REMOVE THE ICE YOURSELF, YOU CAN HURT THE UNIT, let the ice melt, then doulble chech the unit is not set to low in temperature about 60 degrees is plenty or mid way thru the blue sign on the dial, also clean the filter.
Jun 23, 2010 | Goldstar KG6000R Window Air Conditioner
Why will a room air conditioner ice up and can I fix the problem?
Freon leak, How new is it. If you still have a warranty take it back and have them replace it. If it is not under warranty you can try a few tricks. Clean the outside coils with a strong blast of water with the unit off and make sure the filter is cleaned
May 24, 2009 | Goldstar LG LUCKY WG1800R Room Air...
Air conditioner freezing up
Your unit is low on freon. Take the unit to a service facility & have it recharged & the leak repaired. Note that ice formation may normal if the outside temperature is below 45-50F. If you must use it in the meantime, leaving the unit on fan only will melt the ice much faster.
Jul 17, 2007 | Goldstar R5050 Air Conditioner
Air conditioner
If the air flow is restricted or partially blocked (dirty cooling fins, filter etc), ice will form inside becaue the air stays in ithe cooling coil or fils for a long period of time. Lack of freon will not cause Ice formation because there is not enough cooling power.
May 24, 2007 | Goldstar R1003 Air Conditioner
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
