Question about Kyocera Km-1820 Copier Fax Machine
Just recieved a refurbished Kyocera KM-1820 copier that I ordered online. When I make a copy, there is a double line that goes down the middle.
3 Suggested Answers
alvinbga
  • 130 Answers
SOURCE: my Kyocera 1810 copier runs
Clean the glass near where the paper enter the glass
Posted on Jun 11, 2008
  • 241 Answers
SOURCE: I have a kyocera km 1820 copier at work and cannot...
The Kyocera KM-1820 does not have an automatic 2-sided option. This is why it cannot be found in the settings.
Posted on Jun 09, 2010
How to change email addfress for fax
Instructions for registering and editing the address book (fax, email, scanning destinations) can be found on page 5-21 of the advanced operations guide wich can be down loaded from the following link; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14173&rid=14774. THe KM-1820 and CS-1820 are the same machines and this link is for the KM-1820.
Jan 17, 2011 | Kyocera Copystar CS-1820 Black and White...
How do you make a kyocera KM-1820 make 2 sided copies?
Hello, The Kyocera KM-1820 does not support automatic duplexing (double-sided).If a double sided copy/print is required you would have to do it manually, print the first side, then flip the paper over and run it back through the printer again for the second side.
Pre
Jan 14, 2011 | Office Equipment & Supplies
What is the processing unit in a Kyocera KM-1820?
processing unit is the drum unit or the imaging unit in km1820
Dec 01, 2010 | Kyocera Copystar CS-1820 Black and White...
I have a kyocera km 1820 copier at work and cannot figure out how to navigate it to make 2-sided copies???
May 20, 2010 | Kyocera Copystar CS-1820 Black and White...
I am getting an error C6000 on my Kyocera KM-1820 after we had a power outage. I can't seem to get it to turn off. What do I need to do in order to get the copier to work again and for it not to have the...
Go into the service mode ( 10871087 ) then enter 163 then hit the start button. This clears the C6000 (heater error) and if it is a false code due to a power outage, it will clear the code and resume normal operation. If the code comes back, you likely have a bad heater lamp or thermal fuse or thermistor.
Aug 19, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Where is waste toner on kyocera 1820
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
Apr 08, 2009 | Kyocera Copystar CS-1820 Black and White...
KM-1820 scanner setup
The KM-1820 to scan to PC is using SMB, FTP or e-mail.
for SMB:
I am assuming you have the KM-1820 connected within the network and a static IP address for it.
open any Internet browser and go to KM-1820's IP address.
You should see the Command Centre web page.
Go to Basic page and add/register a contact within the Address Book.
Give a name and at the SMB section field, fill up with your computer hostname or the ip address of your computer where you want to scan. Fill up the user name with the local user name - the one what you are using to get into your computer - or create a new LOCAL user for your PC lets say "kyocera". So for SMB will be your computer and username: kyocera. (You will need a password for that computer user (kyocera) ). Then create a folder "scan" where you want ot receive the scanned files and add "scan" at the path field (SMB section of that webpage - command center).
Now share the folder "scan" as "scan".
if you want you can always use the scan to e-mail !! but you need a smtp server. All the settings can be done using that command center webpage.
Dec 08, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Km-1820 Copier Fax Machine Logo
19 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
