Question about Epson STYLUS R350 Photo Printer
Can i use hallmark half fold paper or is my windows 8 a problem
Cleaning a shredder that has sticky paper stuck to the cutters. A EPS-611x.
FIRST MAKE SURE THAT YOU HAVE REMOVED POWER
UNPLUG IT
Using pick remove the paper that is stuck to the cutters,
also you could try shredder oil to assist after you have removed
a majority of the sticky paper...Take a piece of paper fold it
in half, apply a bead of shredder oil the length of the folded paper
Run it through the shredder like you would a plain piece of paper keeping it folded
Sep 05, 2017 | The Office Equipment & Supplies
Tip
Rocket Grill - How to make Inexpensive bags - As low as 2 cents each
Many of us have Rocket Grills which we love, but the bags can be expensive, and it is a pain if you run out of them when you want to use the machine. Here is my solution which I have been using since the machine was originally released. They will hold fat and juice too.
First of all, you are going to need to get some parchment paper. I buy bulk 12 x 16 sheets from a supplier off eBay. (Remember the more you buy, the lower the price). In an emergency you can use a similar technique with Reynold's Parchment paper rolls from the store.
You Need
A. 12 x 16 Parchment Sheet/S
B. Stapler
C. Sharp Pencil or Pen
D. Table or Flat Surface
D. (My Optional Template)
Instructions
A. Take one sheet and fold it in half. so you have an 12 inch wide by 8 inch deep sheet. Crease the sheet by running your finger firmly over the fold.
B. Place the folded sheet on the table, so that the fold is at the bottom as you view it.
C. Now along the short open sides (left and right sides of the sheet), one at a time, fold both layers over as a flap about 1 and a half inches. Try and keep both of these folds to the top.
D. Using a stapler, Staple each side that you have just folded one inch from the top, and a quarter inch from the edge on each side.
E. Turn the parchment paper 90 degrees counter clockwise so that the sealed bottom faces to the right.
F. Take the bottom part of the flap that you created in section C, and fold it back at a 45 degree angle. You should end up having two equal size triangles.
G. Turn the paper back around so that the first fold (A) is at the bottom again.
H. Staple each fold that you just created, about a quarter inch from the top of where the folded edge is. (see picture)
I. Place three equal spaced staples in-between the two staples you just did in section H. You should now have 5 stales in one line, about an inch and a half from the bottom of the bag.
J. Pick up the bag, softly fold it in half in the opposite direction as of section A. Make a tiny crease in the top (Open section). This is so we can find the center of the bag.
K. Place the crease over two of your fingers, and gently push the Pencil or Pen through the crease about 3/4 of an inch from the top. Do not rip the bag) This will be used hold the bag in the grill. (I have cooked 1lb steaks in the grill, and the hole holds the weight fine. Be gentle though)
Comments
A. I know that it is possible for the staples to lightly scratch the grill. However the Grill pads are not designed to come into direct contact with food anyway, and will not damage the grill
B. Some people may wonder about using staples near food. If you use new staples from a clean box you will have no problem. The heat from the grill will sanitize any impurities that may be on them. Also not that it is highly unlikely that your food will ever touch the staples.
C. The pouch at the bottom will hold fat and juice, but depending on the quality of the paper you buy will determine how well the bag holds up. It is possible for the juice/fat to weep through the staple holes, but thats why you have a drip tray.
Thats all folks. Message me if you have any questions.2bda07b.jpg39f5fe9.jpgb6d7936.jpg7040cb1.jpga957872.jpgcbfcbde.jpg
on Apr 17, 2010 | Kitchen Appliances - Others
How does new paper go in
fold the paper about half inch down and feed in along fold
Mar 14, 2016 | Casio HR-100TM Two-Color Printing...
Paper fold and printing problem
Did U try to change drum unit,or maybe transfer roller
Oct 16, 2014 | Canon IR 3300 Digital Copier
I'm not quite sure how to install the sanding paper. I bought this sander in a yard sale. :( Sandy
It depends what kind of sander im going to guess its what is called a pom sander These companys want you to buy the paper from them so there all differant sizes I just buy standard sheets because i use them a lot in my bisuness ripe the sheet in half then fold that in half fit it to the bass then put a small fold at oppisite end of the second fold to make it fit the base and clamp down unless you have a belt sander or a round obrital with velcro this should make some sence to you
Nov 22, 2010 | Garden
Will hallmark card studio 8 work on windows 7
you are going to run on windows 7 since hallmark card studio 8 needs systems configuration such as Windows XP or Vista, Pentium III 500 MHz, 600MB of hard disk space, 2GB for full install,16-bit color, and color printer.
So have fine work!
Dec 21, 2009 | Creative Home Hallmark Card Studio Deluxe...
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
Paper jams when folding 8 1/2 X 11 ivory paper; less often with white. Tech says it's a paper issue - so whose colored paper (brand) will work - or is it a design flaw?
Is this paper the same weight/thickness as the white paper?
Are you specifying the settings properly as far as the weight and type?
It sounds like the sensors are detecting a double feed(?)
Try different settings for the tray, and even try a different brand of stock to verify.
Apr 29, 2009 | Konica Minolta bizhub C450P Laser Printer
Need to print a half-fold card envelope with HP Photosmart C4480
I also contacted HP and they directed me to a workaround which I have not implemented yet!
Mar 07, 2009 | HP Photosmart C5280 InkJet Printer
Epson STYLUS R350 Photo Printer Logo
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
