Question about NEC VT695 LCD Projector
New bulb will not power up
This projector had the bulb changed 1 month ago, it blew and now it will not power up the new bulb. Has it blown the board?
I pressed the Help button on the remote for 10 seconds and it powered up. Not in the manual that you can do this.
Posted on Jun 24, 2009
  • johncarroll Nov 23, 2010
    It is in the manual at the bottom of page E-9 It is in a box that starts NOTE:
Hc1500 projector will not turn on
Sounds like the lamp. The only way to really check it is to either put a new bulb in or put the old bulb in a different projector. Neither of which probably help you at this point. But, it does sound like the lamp is blown.
Mar 30, 2014 | Mitsubishi HC1500 DLP Projector
Dark spot
These bulbs are very sensitive to contamination. When installing a bulb, do not touch it with your fingers, as this will leave your natural oils on it and that will become a hot spot and burn out the lamp.
Use a clean piece of toilet tissue when installing the new lamp to eliminate the above.
Jan 11, 2014 | Sharp XR-10X Multimedia Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
I have a new light bulb 7 months ago and i only have about 100 hours on it why will my projector not start
Have you reset the lamp timer?
If so, what is the status of the indicator LEDs next to the Power button?
Aug 15, 2010 | Panasonic PT-AX100U-EC DLP Projector
Infocus IN72 - blinking RED light
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Mar 03, 2010 | InFocus IN72 Multimedia Projector
Loud Bang and Projector no londger works
If the internal fuse has blown, if you connect the power lead loosely and move it about, you should not be able to hear any crackling sound of electricity. If you do then it is more likely something else other that the internal fuse. Generally, a loud bang is either the fuse or lamp.
Sep 25, 2008 | 3M MP 8749 Multimedia Projector
250V T6.3AH Slow Blo Fuse
Depending upon the way in which the lamp finally smoked, it is not unusual for the feeder fuse to blow. Replace the fuse and try the projector. As long as you haev a new lamp, it should work OK.
Dan
Sep 11, 2008 | NEC VT670 Multimedia Projector
NEC VT695 LCD Projector Logo
879 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
