Question about Sungale DVD9800 DVD Player
How to change samsung dvd 9800 player to multi region
I want to change my Samsung dvd V9800 region 1 player to play multi-region discs (UK, etc.) How do I do it?
How do i make my pc dvd player (Samsung sh-s202) multi regional to play discs from UK and Australia
One option you have is to use ANYDVD, this application unlock the region restriction and you can play or even copy those DVDs.
Good Luck. Remember to vote my answer.
You can find ANYDVD as a torrent.
Feb 18, 2011 | Samsung (SHS202GBEBE) DVD±RW Dual Layer...
Player won't play legally imported DVD's
Hi, guessing you are from the UK? Different countries operate different regions for dvd's for instance the UK dvd players are set up to play region 2 discs, and US dvd players are set up to play region 1 discs.
This is because dvd release dates are different around the world and this stops people buying a dvd in the US and bringing it back to the UK and selling it before its official UK release date for example.
Your choices are either to play the dvds on a PC where often the dvd software will allow you to change region a number of times (be careful though as some players will let you change region say 5 times and then be locked to that region)
Or to get hold of or buy a multi region dvd player which plkays dvd'd regardless of their original region
Hope that makes sense, good luck
Jul 20, 2009 | Electronics - Others
I have a region 2 samsung dvd player. All of a sudden the following message displays: '' Can not play disk. Wrong region code'' We have been playing the dvd for more than 1 year. What is the problem? Same...
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Jul 03, 2009 | Samsung DVD-P181 DivX DVD Player
How to change region codes from only 4 to 2 & 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (mine was 080220.13.B.1080PXKEG)
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear.
6) Now type the code that applies for your region (R4 is 76884). A '4' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
Enjoy
Apr 18, 2009 | Samsung DVD-1080P8/XEU DVD Player
Region code for Samsung DVD-R100a
This is one for DVD-R100 (not R100A). Tell me if it works.
  1. Turn on the player (without a disc inserted)
  2. Press and hold PLAY and FW (or STOP)
  3. "No Disc" is displayed
  4. Release the keys
  5. Press SUBTITLE, REPEAT (or just SUBTITLE or just REPEAT or MENU)
  6. Enter the corresponding combination for your current RC (see top of the page)
  7. Current RC should be displayed
  8. Press the button for the desired RC (9=codefree)
  9. Open the disc tray
  10. Turn the player off
This is another I found.
  1. Power on your player with no disc in the tray
  2. Press REPEAT for 5 seconds
  3. Enter the corresponding combination for your current RC (see top of the page)
  4. Current RC should be displayed
  5. Press the button for the desired RC (9=multi-region)
  6. (Press OPEN)
  7. Power off your player
Apr 12, 2009 | Samsung DVD-909 DVD Player
No disc on samsung
Hey,
For clarification, was this home theatre system purchased in North America? If so, in all odds it is a "Region 1" DVD player. To play a "Region 2" video, you will need either a 'multi region' player or one that is designated as a "Region 2"
regards,
Hortona
Mar 24, 2009 | Samsung HT-DS100 System
Trying to de code my samsung dvd/vr 355 to play multi regional dvd
samsung dvd vr355 hack (uk model only)
remove dvd
switch on
press dvd button
press menu
press 57538 (76884 for non uk)
a number will appear in top left corner i.e. 2
then press 9 for multiregion
press open
switch off
player should be multi region now
Hope this helps.
Thanks
Sep 13, 2008 | Televison & Video
Samsung BP_D1400 region code
I,m not aware Of Any Blu-Ray DVD Hacks.
For That Actual Player Yet.
Search Here:-
http://www.dvd.reviewer.co.uk/info/multiregion/hackable.asp?Page=68
Mike @ Compurepair.
Feb 29, 2008 | Samsung BD-P1200 Blu-Ray Disc Player
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Sungale DVD9800 DVD Player Logo
173 people viewed this question
Top Sungale Televison & Video Experts
Henry  Thomas
Henry Thomas
janman
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
