Question about Jon Dicks What a Carry On
How to get deleted date back on nike plus ipod
Tip
How to use the Nike + iPod Sport Kit
1.Place the sensor in your left Nike+ shoe - in the built-in pocket beneath the insole. You can leave the sensor in your shoe even when you're not working out. 2.Attach the receiver to your iPod nano. It fits snugly into the dock connector, located on the bottom of iPod nano next to the headphone jack. iPod touch has built-in Nike+ support, so no receiver is necessary. 3.Hit the ground running with workout-based voice feedback, Nike Sport Music content, and your favourite playlists or songs that keep you pumping.
on Oct 27, 2010 | Clothing Accessories
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
How does the iPod Nike running monitor work?
The Nike GPS monitor fits into your sneaker and you can track your progress on your iPhone or iPod with a special app. You can download the app from the iTunes app store.
http://nikerunning.nike.com/nikeplus/v1/pdf/English.pdf
Jan 14, 2013 | Running
I want to know how delete and reinstall data on my ipod model no. A1136
it really does not matter the model...... this goes for all MP3 devices.... do you have your MP3 files backed up on Itunes or they can be replace right...ok
attached Ipod to PC... Itunes will load /pop up (close it ....out ... this is a must)
now go to start / my computer see the device (Ipod).. open it , copy all the folders plus hidden ones
save these folders to your PC in a Temp folder....you should have at least 3 plus 1 or 2 hidden folders
okay are the folders are copied to the C drives? yes... go to the device and right click and format the IPOD yes this will delete the whole ipod....its finished now you must go back to that Temp folder and copied all the folders and paste back on to the IPOD.... Okay open the Itunes and place all your files back on to your new as it use to be IPOD ...now enjoy
and Seasons Greetings
Dec 24, 2010 | Audio Players & Recorders
Strap Replacement
Maybe you can use it on an armband like with an iPod. Even with velcro.
Jul 24, 2008 | Nike Triax C5 Wrist Watch
Facebook Apps Logo
16 people viewed this question
Top Jon Dicks Facebook Apps Experts
Allen Lightsey
Allen Lightsey
Level 1 Expert
Are you a Jon Dicks Facebook App Expert? Answer questions, earn points and help others
