Question about Garden
I have a wagner 437 paint sprayer that "almost primes"...it was sitting for three years and I am the new owner. Is there a manual or do you know what the issue might be?
  • 4088 Answers
SOURCE: Need an owners manual for Wagner lumberjack
This sounds like investing in a dead horse. Please look into a modern equivalent--they are not terribly expensive and deliver more horsepower with less weight. Good luck!
Posted on Jun 23, 2010
  • 700 Answers
SOURCE: I have a wagner airless
Yes, yo can repair it. there is compound problem with the unit. Please use this advice for future to save yourself time and money.
Before you store any painting equipment for longer than few days:
1. Strip equipment to base pieces,
2. Clean them with paint stripper
3. Wash them in water and then dry them through
4. Wash them in solvent, dry them, put vaseline on rubbing parts
5. Store in dust protecting rags or bags
You just used your gun without cleaning it, that was part of the problem, gqasket on the bottom of the piston was weakened by paint and two years of storage, you did not strain paint, you just used it directly from the can. chunky bit from the can (there are always bits forming around the toip and sides of the can) clogged piston, giving impression that there is no paint, you incresed the pressure and gasket give up on you...
Just follow advice, clean the gun, put it to pieces, find which gasket (I suspected that this one will be from the bottom of the piston), most of hardware stores have spares for these guns, buy exactly same dimension, put gun back together and this should solve your problem.
I do that sort of the "surgery" on the tble with several layers of old newspapers under and last laer butchers paper, I put my pieces in order in which i removed them so I can easy put them back together. Always strain paint, always clean gun...
Hope this will help solve your problem :-)
Posted on Aug 08, 2010
  • 2841 Answers
SOURCE: looking for a manual on
You can download a manual here. If you unit is discontinued then click Discontinued Product Manuals. If you have a newer unit just click Power Painter and download the manual in PDF format. http://www.wagnerspraytech.com/portal/wagner_product_manuals_spray,347943,747.html
Posted on Sep 20, 2010
puertobori
  • 7733 Answers
SOURCE: I have bought a repair
Go to this LINK.
Posted on Oct 26, 2010
  • 250 Answers
SOURCE: I used this brand new
You have to take it apart and there is a ball check stuck open. Tap the ball with a wooden stick to free it up.
Posted on Mar 18, 2011
Remove and Install prime/spray valve Wagner paint crew airless paint sprayer?
Was the unit purchased new or used? The price of a new is about $125-170. This unit is for homeowner occasional use, not for large jobs.Was the unit working on the previous use? If so were the cleaning instructions followed and not shortcut. If paint is failed to be totally removed on cleanup it will dry inside unit.There are very few replacement parts for this unit. If the unit is not working take wrench and try to remove prime/spray valve. You will have to remove knob to access this part.
Apr 18, 2017 | Wagner Air Tools & Compressors
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Won't prime
Try to trouble shoot the problem by doing this:
clogged filter(s)
you did not clean paint out of machine properly on last use
the packings are worn and need to be replaced- it wont hold or build pressure- also that sprayer has a max tip size of .15
Feb 18, 2014 | Wagner Tools & Hardware - Others
Won't prime
You either have a stuck ball valve, or a leak in the paint suction
Feb 09, 2014 | Wagner SprayTech Wagner Airless Paint...
Unit won't prime,
YOU HAVE A STUCK INLET BALL
Have the unit in water, pressure relief valve turn the machine on and tap with a hammer at the inlet ball, This frees it up 90 of the time.
Otherwise the machine need to be disassemble
Jan 29, 2014 | Wagner SprayTech Wagner Airless Paint...
Will not prime
Most of the time when a unit will not prime it is because of a stuck inlet ball, I would put the intake in water turn the machine on to bleed. Then tap the machine where the paint comes in. 90% of the time this will get it going. Sometime you can stick a screw driver into the inlet ball and free it up. If this doe not work you need to take the machine apart and cleanor you have worn out packing.
Joe
Jan 23, 2014 | Wagner SprayTech Wagner Airless Paint...
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
I have a Wagner 834cw15. Spraying fine 10 mins ago. Now...can't get it to prime. Any suggestions? Spraying oil based kilz
http://www.wagnerspraytech.com/portal/loader.php
I cannot find model 834
Check your owner's manual for troubleshooting steps
We used paint sprayers every day for years.
The prime valve goes bad
The steel balls that direct the paint between prime and hose, wear out
The steel ball that holds prime and hose pressure wears out
The steel balls can also get stuck
Turn prime lever on
Take a hammer and tap/bang front of paint sprayer until ball comes loose
I cannot see your sprayer so I don't know where the ball is located
The photo below says, keep lever up >> in your case lever is down or in prime position while tapping
To post a photo of your paint sprayer so I can see it:
Read:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answersAnd then add comment at page bottom and it sends me an e-mail
I will be here for another 45 minutes. Its 526 cst
Oct 26, 2010 | Air Tools & Compressors
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
